Do I need to add relays if my alarm has neg/pos outputs?
Old Jul 30, 2006
digitu's Avatar
digitu is an unknown quantity at this point
Question Do I need to add relays if my alarm has neg/pos outputs?
Im installing an alarm (Prestige APS-800) on a 2005 Honda Civic DX. Ive installed power door lock actuators already and was wondering if I could just wire the actuators directly to the brain or do I need to add 2 relays? I think since the brain has negative and positive outputs I can wire it directly to the brain, but Im not sure and dont wanna fry it.
Thanks,
T
Old Jul 31, 2006
cannonfolder's Avatar
cannonfolder is an unknown quantity at this point
I would wire it directly because those modules act as a relay built in.
Old Jul 31, 2006
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Thanks,
T
You definately need to use two relays if you are powering up aftermarket actuators. The voltage coming from the " brain" wont be high enough to power up the actuators and you'll probably mess something up. Aftermarket actuators need 12V+ to function properly. If you need help on wiring it up send me a PM.
Old Aug 1, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
couldnt agree more, most brains will only put about half an amp of current on the lock/unlock outputs. Thats usually enough to trip a relay.
Its pretty easy to wire up the two relays. If you dont wanna bother with it, get a door lock relay module from dei, part # 451m
Mucklow
Aug 22, 2015 06:28 PM
JetsterDajet
Aug 16, 2015 01:56 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
