Which setup is better?
Old Jul 22, 2006
WKHCivic's Avatar
WKHCivic will become famous soon enoughWKHCivic will become famous soon enough
I have two eclipse 12's.
I can either get two XA1000's or one XA2000. I was wanting to know which setup would get me the most power. Thanks
Links:
XA1000:http://www.eclipse-web.com/amp/xa1000.html
XA2000:http://www.eclipse-web.com/amp/xa2000.html
Old Jul 22, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
I would think that each subwoofer having its own amp powering it would produce better results. At least that's my theory
Old Jul 22, 2006
WKHCivic's Avatar
I wasnt sure, cause i thought sometimes the amps didnt always put out what they said.
Old Jul 22, 2006
Civicman1988's Avatar
agree each sub produce a better sounds just dont max tehm out they will sounds like crap
Old Jul 22, 2006
WKHCivic's Avatar
well my subs can handle up to 600 watts, so you think the one amp on each sub will be ok?
Old Jul 27, 2006
wicivic's Avatar
wicivic is an unknown quantity at this point
eclipse amps suck now... that used to be the only system i ran but since they went mass produce.... bleh but get one amp for each sub.... but i would get 2 of the 1000's because its closer to the rms of your sub.. oh and if you are going with an eclipse headunit get it before 2007 because they are stopping the electronic tracking chips
Old Jul 27, 2006
WKHCivic's Avatar
i actually already have an eclipse head unit and i think i have decided to go with an alpine mrd-m605 instead of the two eclipise 1000's since my eclipse dealer wants 1050 for the amps and to install them and i can get the alpine instaled for 460-500
Old Jul 28, 2006
wicivic's Avatar
wow they want way too much for those amps... go to www.sonicelectronix.com thats where i get all my stuff now
Old Jul 30, 2006
WKHCivic's Avatar
are all the products from this website brand new and in good shape?
Old Jul 31, 2006
wicivic's Avatar
unless it states refurbished everything is NIB... the refurbished stuff is usually in the clearance section i ordered 2 audiobahn eternals a couple weeks ago and an A180001DT it got here i think last wednesday and everything was perfect.... If i may reccommend some things for you.... unless you want to stay all eclipse, which is understandeable kicker makes an awesome amp, audiobahn is excellent, MA audio is pretty good, and of course fosgate is good
Old Jul 31, 2006
WKHCivic's Avatar
I think i am gonna go with the alpine mrd-m605 what is your opinion on that?
Old Jul 31, 2006
Dominatorp1's Avatar
Dominatorp1 is an unknown quantity at this point
Just make sure if you have two subs with two amps not to have the subs in the same incloser.. even though they are the same amp the watts are not always the same.. if you have them int he same incloser make sure they are seperated with MDF or fiberglass.
Old Aug 1, 2006
wicivic's Avatar
it looks like a pretty good amp from what i read.... ive never used an alpin amp so i cant give you a definite answer though
