window fuse question
Old Jul 24, 2006
zackde's Avatar
zackde is an unknown quantity at this point
my window on the back left hand side wont open or close, i dont know if wiring, motor or the switch is the problem
do all four windows has individual fuse? if its a fuse problem im safe, where can i find the fuse for the windows?
civic 02 ex sedan
thanks guys
Old Jul 25, 2006
CraigW's Avatar
Fuse #s 24 & 25 in the under dash box = 20 Amps. Are the fuses for the rear windows.
Old Jul 25, 2006
zackde's Avatar
i checked the fuse and its ok, the switch might not be the problem because the drivers switch & the passenger switch is both not working, any help on what to check next?
thank you
Old Jul 25, 2006
CraigW's Avatar
I can offer up the wiring info for you if you have a meter and want to check some voltages. PM with E-Mail and I can send it to you.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
beveragemp
May 25, 2015 07:11 PM
werdnahall
May 17, 2015 11:37 AM
viper775
Dec 9, 2001 10:52 PM
