wiring components
Old Jul 14, 2006
john_817's Avatar
john_817 is an unknown quantity at this point
wiring components
is it ok to wire components by tapping into the harness and while using the stock wiring while connecting the speakers with a speaker wiring harness? like this
or should i wire it directly like this
or is it both the same? suggestions please..thanks
Old Jul 16, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
it's better to wire it directly with new and bigger wire than stock, but you can do it the other way too, but if you do, make sure you dont connect the 8 speaker wires from your headunit to the car harness, cause you'll be sending the amped signal to the headunit.
Old Jul 16, 2006
john_817's Avatar
what do you mean make sure i dont connect the speaker wires from my headunit to the car harness? the harness is connected to the headunit so do i need to disconnect it?
Old Jul 16, 2006
05reverb's Avatar
your using the RCA's to send the signal to the amp, so don't connect the 8 speaker wires (grey, white, purple and green) from the headunit to anything, cause if you do it like in the first pic and use the factory wires to the speakers, it will send the amped signal to back to your headunit. are you powering the 4 speakers with that amp, or just the 2 fronts? if only the 2 fronts, leave the green and purple wires connected and and dont connect the white and grey
SimpleUser
Apr 24, 2021 02:54 AM
Strycker
Aug 2, 2015 08:40 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
sch2cm
Jul 21, 2015 09:58 PM
robbie374
Jul 7, 2015 02:56 AM
