Getting power to my amp???
Old Jun 6, 2006
trev98's Avatar
trev98 is an unknown quantity at this point
Ok I done some searching and read somthing about using other wires or somthing anyways Im not that hot on this stuff never done it before. But Im going to use the stock stereo and tap into my rear speaker with a converter. I was wondering how can I get power to my amp??
Old Jun 6, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
hey, i know your new to this site but this has been covered many times. search. there is a DIY on amp wiring in the ice section pretty sure.
Old Jun 6, 2006
trev98's Avatar
yea i have been searching but im just not sure where to go for a power source if somone could explain like where its at in the car and stuff be great its a 2004 civic coupe
Old Jun 6, 2006
Rennen's Avatar
New Mod on the Block
umm... are you serious? if you have to ask that question, you NEED to take it to someone who knows what they are doing. first of all, you need some 4 awg wire. enough to get from your battery to your amp. and do you know why it needs to be that long? you got it!!! cuz you connect the + terminal of the battery to your amp.
Old Jun 6, 2006
oh no please stop and take it somewhere. it can be very dangerous if you're not careful.
Old Jun 6, 2006
kingofheartz's Avatar
kingofheartz will become famous soon enoughkingofheartz will become famous soon enough
especially if u forget to disc. the batt
u should find someone that has a bit more knowledge to help ya
Old Jun 6, 2006
if you're anywhere near central illinois, i would say bring it by my place.
Old Jun 6, 2006
trev98's Avatar
Well im not that bad now ive already had the back of my stereo out hooked my ipod up and stuff but my buddy is going to help me. He done it in his sunfire before.
Old Jun 6, 2006
okay cool. basically the amp needs a power wire run directly to the + battery terminal (with a correct size fuse within 1 foot of the battery). than for the ground wire, you can bolt it to the metal chassis near the amp like the metal under the seat. for the amp to actually turn on with the deck, you connect the remote turn on wire. then you connect rca plugs from deck to amp to send the signal, then you run speaker wires from the amp to the speakers (or main factory harness which leads to the speakers).
dont forget to pick the correct size power wire depending on the power in rms watts that the amp puts out.
Old Jun 7, 2006
trev98's Avatar
Its a clarion amp 400 watts can I just get a power wire at walmart or canadian tire or something??
Old Jun 7, 2006
how many rms watts total? peak watts has no meaning for anything. i have a 4 ch amp 30wx4 = 120w and im using 8 gauge wires. i would just goto circuit city or best buy and get an amp wiring hookup kit just tell someone what you're using. its always better to go with smaller gauge (thicker wire) if you're not sure. should come with almost everything. they also sell special speaker wire that is all bundled (all 8 wires in one tube) to make it easier to run.
Old Jun 7, 2006
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
duck and cover.......
do yourself a favor and let a professional installer help you..
Old Jun 7, 2006
jungleheadjim's Avatar
jungleheadjim will become famous soon enoughjungleheadjim will become famous soon enough
i would not take it to best buy however. they wired up my amp and when i was sitting there i heard hammering. wasnt sure what he was doing but he was bangin in the connector for the power with a screwdriver. the amp ended up dying 2 days later because the power and ground connectors were loose. he broke them.
take it to a place that specifically sells car audio and does custom audio.
Old Jun 7, 2006
trev98's Avatar
I havnt got access to profesional I live in a small community and its a long ways for a place that does stereos the amp puts out a true 400 watts
Old Jun 7, 2006
400w RMS? if so you're gonna need some thick cable, at least 4 gauge if not 2 or even 0. may want to post in the ice forum about it cause i dont really know what size.
Old Jun 7, 2006
Dominatorp1's Avatar
Dominatorp1 is an unknown quantity at this point
I sell car audio and if you are running 400W max then you can got for 8 gauge and if you are running even 700watts max you can still for 8 gauge but make sure its a good company like stinger, dont go for i-connects they are looser packed. If you go to Besy Buy or Futur Shop take a look at there wires, they all have ratings on them.. Even go on there websites and find out that way. If power is any more than 700watts then you want to go to 4 gauge..
Old Jun 7, 2006
diskreet's Avatar
Please be careful. installing an amp is a very simple thing, if you have a good knowledge of electronics.
Since you obviously don't, take your time, and double check everything.
Remember:
*Fuse within 18 inches of the battery + terminal.
*Ground as close to the amp as possible. Make a new hole in the metal somewhere near the amp and sand the paint off around the hole so the screw contacts as much as possible.
*Use same gauge wire for power and ground (make both 8 or 4 gauge with that much power. Either will work safely, but 4 is better.)
*Disconnect the battery's - terminal till everything is completly hooked up.
*Add the fuse in after all the install, and AFTER the battery's - terminal is reconnected. Doesn't really matter, but this is the safer way to do it.
There are many small points, so read up and take your time!
Old Jun 8, 2006
trev98's Avatar
thanks alot for the help probly well attempt it saturday lol
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
Dave1984
Jul 22, 2015 06:10 PM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
