amp dead?
Old Apr 25, 2006
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
amp dead?
Im wondering how easy it is to kill your amp? I took a turn and my set-up shifted and ripped the power wire off of the capacitor and when I re-wired everything the amp will not work. I checked with a test light and a DVOM and both showed that the was voltage at the amp but nothing happened, amp wont turn on and subs wont hit. The remote also has power to it. Ground is also good. I dont know what is wrong with it other then it being broken. All the fuses are also in good condition and the capacitor still works! Sorry for this being so long Im just wondering if I broke my amp which was very expensive. Thanks in advance
Old Apr 26, 2006
jeffsta17's Avatar
anyone?
Old Apr 26, 2006
DJayG's Avatar
DJayG is an unknown quantity at this point
Does the amp light up, what kind of amp is it. If you definately metered your wires and there is nothing turning on then the amp is dead. If it turns on and the speakers dont play then maybe you broke the RCA's during the fall.
QUICK FIX GUIDE:
Secure your equipment for mach 3 around turns j/k
Old Apr 27, 2006
jeffsta17's Avatar
yeah its a power acoustik amp and its friggin brand new, all the wires did check out but i didnt check the rca's but i figured the amp would turn on without them right? and yeah about the turns it was actually sharper then i was expecting lol.
Old Apr 27, 2006
free_refil's Avatar
free_refil will become famous soon enoughfree_refil will become famous soon enough
Wow that's a bummer. Sounds to me like the amp's fried. Take it in to a shop and have them put it on a bench to see if they can get it up and running.
Old Apr 27, 2006
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
did you check the fuse on the amp?
Old Apr 27, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
when you say the power wire ripped off the capactior, is their any way it coulda have shorted out to the output terminals of your amp? sending 12 volts dc into those terminals could easily kill an amp
Old Apr 27, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Huh? thats new.. amps run on dc voltage... Anyways. did you just visually check your fuses? Or did you check and see if there was resistance on them to make sure that they were good. If you just did a visual check you could be wrong, cause a lot of times the fueses can apper to be good, when in fact are blown. Also have you tried checking your grounds or removing the cap? Just rule as much out as possible before you take it in and see if its blown.. You do have a warrenty on it right?
On a side note, why you dont have things mounted down so you dont rip wire out in the first place just baffels me.
Old Apr 27, 2006
jeffsta17's Avatar
it was a quick install so the whole mounting thing was a little over looked, i just visually checked the fuses so yeah i will see how much resistance they have. The grounds are fine and yes i tried without the cap still no results. thanks for the input guys
Old Apr 28, 2006
actually the output stage of an amplifier operates on AC. Music is a sine wave and cant be reproduced with direct current.
Old Apr 28, 2006
The output true, but not the input.
Old Apr 28, 2006
well im glad we agree
Old May 1, 2006
PopcornPlaya's Avatar
Electric Boogaloo...
Check all your fuses with a DMM. Check all your wires from front to back, make sure none are touching anywhere. Does it light up? Thermal light come on? If all else fails it should have a warranty. And secure them amps please. They can become a projectile in the wreck and hurt you worse than you would be had they been secured.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Skunkone
Sep 24, 2015 04:38 PM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
