Head Unit Swap
Old Apr 23, 2006
IceVic05's Avatar
IceVic05 is an unknown quantity at this point
Head Unit Swap
Tried searching, got nothing, but i am switching from a dual headunit to an alpine. Is there anything I need to get, the dual is an aftermarket obviously but I just want to make sure its just a plug swap before I spend time working on it haha
thanks
Old Apr 23, 2006
Stearic's Avatar
Stearic is an unknown quantity at this point
It should be relativly easy to swap the decks out. You can re-use the adapter (i'm asuming here you bought one) that plugs into the stock adapter for your car and just re-wire it to go with the new deck. Pretty simple to do as long as you follow the instructions regarding what wire is what.
Old Apr 23, 2006
yup just cut and slice the wires from the alpine deck.
Old Apr 24, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
he might have to get the dash kit (if it going from dual din to single) if go to dual to dual deregard this post
Old Apr 27, 2006
luvvegas777's Avatar
banned from avatar useage
luvvegas777 is an unknown quantity at this point
he means Dual(the brand) as gearbox said, just cut one wire at a time, and match color for color.
Old Apr 27, 2006
Al Gore FTW's Avatar
jdmtytedoridori
edp22
Jan 27, 2002 02:51 PM
oblivious9
Jan 25, 2002 10:28 PM
bobbyd
Jan 7, 2002 01:31 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
