Tool needed for perfect circles?
Old Apr 11, 2006
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
I wanna be able to cut perfect circles... MDF & plastic... what tool is good for the job?
Old Apr 11, 2006
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
router
Old Apr 11, 2006
paradoxblue's Avatar
circle cutter
circle drill bits.. if small. will workf or tweeters. or yes a router with the circle attachment.
Old Apr 11, 2006
dp_yz713's Avatar
Boobies are the mans tinkertoys
dp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to behold
draw a perfect circle with a compass and use a jigsaw to cut it out. just take your time and it will be perfect. perfection takes time that all
Old Apr 11, 2006
jcem's Avatar
jcem will become famous soon enoughjcem will become famous soon enough
Rotozip
Old Apr 11, 2006
stinkypie's Avatar
A big, hairy Kentucky boy
stinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to all
I second this. If you want the edges rounded, use a router afterwards. You can always sand it down as well.
Old Apr 11, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
if your going to only be doing one or two a compass and jigsaw with a steady hand will do the trick.
otherwise invesnt in a router and jasper jig. i love mine. it makes flushing objects much easier and gives a more professional look
Old Apr 12, 2006
MegaHurtz's Avatar
If you want perfect circles, use a router
If you want "good enough" circles, use a jigsaw
Old Apr 12, 2006
vietfob714's Avatar
yeah... i wanna be able to cut circles and later make things flush
Old Apr 12, 2006
ajhdragon's Avatar
7thgens official a$$hole
thats my theory, i can afford good enough so i use that option. $30 for a jig-saw vs $100 for a router.
Old Apr 12, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
If its not deep you can use a dremal tool as well.
Old Apr 14, 2006
diskreet's Avatar
If you are cutting by hand then cut a little inside the lines and they use a router to finish it off.
Old Apr 14, 2006
djc's Avatar
djc
djc is an unknown quantity at this point
if you can get access to a band saw you'd be good to go...
Old Apr 14, 2006
manahoonie's Avatar
measure your radius.
get these tools:
piece of string.
thumb tack.
pencil.
with these three items, you can draw perfect circles. then cut a little inside the circle, and work out.
Old Apr 14, 2006
WhiteRabbit's Avatar
router. you can mount it on your own piece of 1/4 inch ply or hardboard. just something flat.
simply drill a hole where you want your radius to be. then punch the same bit into your workpiece. I use an old broken bit.
the circlecutter wont wiggle, and the cuts come out perfect, even through multiple passes.
Old Apr 14, 2006
ajhdragon's Avatar
i have a solution for everybody. do like me and just get square subs, Solo Barak owns
Old Apr 15, 2006
I hope your avatar isnt a picture of yourself....
Old Apr 18, 2006
Zeppelin8778's Avatar
Zeppelin8778 is an unknown quantity at this point
im just dropping in to comment on the fact that the title contains both the bands "tool" and "a perfect circle".... interesting... maybe its an omen since im goin to see tool on MAY SECOND! woot. maynard pwns.
Old Apr 18, 2006
used to, anwyays. the new album will have to speak for itself.
where is tool playing may 2nd?
Old Apr 18, 2006
well personally i found lateralus to be amazing, so ive seen nothing i dont like from tool. ive never been a perfect circle fan at all though... its average. they are playing at tha paramount in seattle on may 2nd
Old Apr 18, 2006
pass.
mattdoc
Mar 14, 2017 12:10 PM
bsmiley
Apr 27, 2015 01:27 PM
Myredjonda
Apr 14, 2015 07:00 PM
