two quick questions....
Old Apr 2, 2006
msi1337's Avatar
msi1337 is an unknown quantity at this point
1) what are the dimensions behind the seats for an amp wall (inside the trunk...sedan)?
2) is it okay to split the remote wire to turn on two amps? If not, whats the proper way?
Thanks!
Jason
Old Apr 2, 2006
James77's Avatar
James77 is an unknown quantity at this point
I'm not sure of the dimensions but for the remote wire you should be ok to split the remote. The other way you can do it is use a relay.
Old Apr 2, 2006
BrynDN's Avatar
BrynDN should not be trusted
You should be safe with two amps only. Going to more amps, or powering neons or other devices, will have you searching for a new head unit very quickly.
Tedverseti
Apr 23, 2020 01:45 PM
ricer_em2
May 11, 2016 08:09 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
metalpres
Sep 23, 2015 05:22 AM
