Subwoofer Noob
Old Mar 26, 2006
pgonzo2k's Avatar
pgonzo2k is an unknown quantity at this point
Exclamation Subwoofer Noob
HI GUYS I WANT TO BUY THIS SET..IS IT GOING TO BE LOUD? COMES WITH THE ENCLOSURE AND THE WHOLE NINE YARDS...WOULD THIS BE FINE AND HOW WOULD I WIRE THE AMP TO THE SUB,,THERES LIKE 3 THINGY AT THE BOTTOM OF THE PAGE THAT I DONT UNDERSTAND,,,THANKS IN ADVANCE
DO ANYONE HAVE THE SAME SETUP???
IS THE BASS LIKE BANGIN LOUD???
SUBS
2 12" High Performance Subwoofer(AUDIOBAHN AW1251T)
45 OZ. Strontium Magnet
2" 4 Layer Black Aluminum Voice Coil
400W RMS Power Handling Per Sub
800W RMS Power Handling Per Pair!
24Hz - 1kHz Freq. Response
92.1dB Efficiency
Dual 4Ω Voice Coils Per Sub
1 Ohm or 4 Ohm or 2 Ohm Stereo Operation
AMPLIFIER
Brand New Ultra Linear UL2600D 1200w Car Amplifier
MOSFET Class A/B Circuitry
DC To DC Circuitry
Power / Protection LED
Low / High Level Inputs
Line Level Outputs
Chrome Plated Screw Terminals
Thermal / Short / Overload Proection Circuitry
Variable LPF / HPF Crossover
Adjustable Input Sensitivity
2Ω Stereo Stable
Bridgeable
Tri-Mode Operation
2x 25A Fuses
Frequency Response 20 - 20KHz
S/N Ratio > 90 dB
Dimensions: 10"W x 2-1/2"H x 12"D
1200W Max Power
300W x 2 RMS @ 4Ω
450W x 2 RMS @ 2Ω
600W x 1 RMS @ 4Ω
Old Mar 26, 2006
blackout881's Avatar
blackout881 is an unknown quantity at this point
s
should bump good..i have a 480 rms 920 max kenwood amp to a 12" 500rms 1000 max rockford sub..pretty loud..as for wiring, dont **** it up or you'll burn your amp out or set your car on fire haha.. just read a DIY on amp wiring or something. or i'll explain it wheni have time, pm me if you want
Old Mar 26, 2006
James77's Avatar
James77 is an unknown quantity at this point
You are under powering your subs but it should be loud enough for you. As for wiring go here http://www.the12volt.com/caraudio/wo...igurations.asp and put in 2 4 ohm Dual Voice coil. It will give you 2 options. 1 ohm wired in Parallel and 4 ohm wired in series/parallel. You have to wire it the second way that gives you 4 ohm. Your amp isnt stable to 1 ohm so if you wire it like that you will end up over heating your amp, which will cause it too turn off all the time and burn it out quicker.
Old Mar 26, 2006
pgonzo2k's Avatar
ok,,thanks guys ... ill just buy the box and subs,,,ill get a seperate amp,,,,any suggestions for the amp?? dont want to spend that much
Old Mar 26, 2006
James77's Avatar
Depends how you want to wire it. You only need a mono amp or you can look for a 2 channel that you can bridge to mono. Look for something that puts out 800 W at either 1 ohm or 4 ohm.
Old Mar 26, 2006
pgonzo2k's Avatar
alrity,,,,ill look at it when i get back home...
Old Mar 26, 2006
Rufus's Avatar
Those subs suck. Sorry but I killed one with a JL 500/1 while I was waiting for Diamond Audio to fix my subs.
Also RMS is what really matters with amps. Just wait until you compensate for less power by turning up the gains, clip the sub, and drive home without any bass....
Old Mar 27, 2006
pgonzo2k's Avatar
thats why im lookin to buy a diff amp,,,an amp that will give sufficient power to the sub,,,,anyway the rms for those subs is 400 so givin it 500 would surely break it
Old Mar 27, 2006
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
im not too found of audiobahn (i owned a pair of their subs and 2 of their amps). as for that amp/sub setup, its not the best but im sure it'll work for starters.
the bass wont be extremely loud, but it'd be enough to shake up your rear view mirror pretty bad. as for loudness and being heard down the block, i doubt it.
id personally look into something else unless you can get this setup for dirt cheap
Old Mar 27, 2006
Rufus's Avatar
One thing you'll learn with car audio is that what they CLAIM and what the amp pushes can be totally different. you get what you pay for. Listen to people in Audio Forums and you'll get an idea of whats good. Here's a good buy depending on what it ends up selling for...
http://cgi.ebay.com/ebaymotors/preci...spagenameZWDVW
Old Mar 27, 2006
pgonzo2k's Avatar
what about one solobaric l7 th new one and and a good amp?
suggestions please...most i could spend is 300 to 400
Mad Dog Tannen
Oct 19, 2016 08:12 PM
wingsfan19
Oct 1, 2015 03:45 AM
wingsfan19
15
Sep 2, 2015 02:15 AM
wootah88
Jul 21, 2015 10:22 AM
LudlamTheory
Jul 28, 2002 03:45 AM
