changing front speakers & tweeters
Old Mar 12, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
It was very nice out today, so decided to remove my door panel to see how big a job i'm gonna have this summer to change my stock front speakers and tweeters.
I have Infinity components, I tried one to see if I need a spacer and of course I do, that factory hole is small.
And I was looking how the factory tweeter was in the sail panel, and was wondering if any of you replaced the stock tweeter with another and how did you get it to hold???
Also, did any of you pass new wires for the new speakers? If so was it hard to do??
Anyways, I took some pics, so Megahurtz, if you want to add them to the current DIY, there all yours! I'll post more pics when finnished, today was just to see how big a job it was.
Old Mar 13, 2006
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
I have boston comps - the tweeter fit exactly into the sail panel with no issue - I had an installer (tweeter) run the wiring through my doors and handle the custom MDF spacers and in door crossover mounts..
Old Mar 14, 2006
05reverb's Avatar
yeah me too my infinity tweeter fits in too, but the factory tweeter is held by a screw in the back, wich the infinity does not have a screw hole, so how did you get it to hold? did you glue it there? also, are you still using the same wires, or did you pass new wires for the speakers?
Old Mar 14, 2006
nighthawk1903's Avatar
nighthawk1903 is an unknown quantity at this point
how did you get the mirror cover off? i tries to take my door off to install my infinity 5.1 perfects componets an couldn't get the door off? thats probably what was holding me up? just want a little more info.
Old Mar 14, 2006
stepchild's Avatar
stepchild is an unknown quantity at this point
My Door project. 2001 Civic LX
I also have Infinity Components. As far as tweeter mounting I did not have factory tweets so I just used the supplied mounting options with the components. You might want to consider just buying sail panels w/o tweet mounts in them (LX/DX). They are cheep from Honda.
I ran my own wires for everything. I did not use any factory wiring accept for power,remote for head unit. It's easy to run wires from the door into the car. There is actually a hole in the rubber grommet that connects the door to the jamb, at least there was in my car. I just ran it through there. I also mounted the crossover to the door itself. I had to cut away the plastic that is attached to the factory grille on the door panel. It all takes time but I was happy with it. MAKE SURE YOU USE SOME KIND OF SOUND DEADENING MATERIAL!!!!!!!! I used dynamat with the aluminum backing and it works great. A little heavy but it's worth it. There is also a preforated part of the factory rain guard (white plastic on the door panel) that you will need to keep. It is for the foam that extends from the door panel into the door.The foam is used as support for the window when it is down. If you are not trying to seal the door with dynamat or whatever then you don't have to worry about it.
If it is hard to push the wires through the grommet or tube with the other wires just spit on the wires or you can spend money and get something from Lowe's (wire lube or gorilla snot or something) I hope this helps.
Old Mar 14, 2006
05reverb's Avatar
It just pops off, there is only 2 clips holding it.
Stepchild----> Thanks that helps alot. So wich way did you feed the wires? from inside the car to inside the door, or from inside the door to inside the car?
Old Mar 14, 2006
coop's Avatar
My wiring runs to a crossover inside the door....the crossover connection to the amp runs through the "accordian" that runs the rest of the power window/door wiring.
Old Mar 14, 2006
paradoxblue's Avatar
im considering putting the cross over in my doors.
mone are pg which have a single cross over. but the pcb is perfereated to snap in half for split mounting.. hmmmmmm
Old Mar 14, 2006
05reverb's Avatar
thanks coop. I know it has to go threw that acordian shaped rubber, I need to know how did you get it threw, and if it was hard, and wich way did you pass the wire from (starting from inside the door or starting from inside the car). thanks again!
Old Mar 14, 2006
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
infinity kappa tweeter mounted using the infinity Starfish mounting brakets that come with all new infinitys
Old Mar 14, 2006
05reverb's Avatar
Originally Posted by LowSky
what sail panel do you have there? is it the factory with or without tweeter?? I have the factory tweeter sail panel, and it doesn't look like yours. Your tweeter sticks out more.
I don't think my infinity's have the same mounting stuff, mine are the 2005 models (the white ones)
Old Mar 14, 2006
LowSky's Avatar
mine are the 2005 models too
kappa 60.7cs
those are the normal EX coupe tweeter panels... use the Starfish mounting brakets like i did.. the tweeter sits out more but it still looks stock
right off crutchfield.com
* I-Mount Tweeter Mounting System: The tweeters can be surface or flush mounted with Infinity's innovative I-Mount system:
o Surface Mount: Surface mounting the tweeters involves screwing the surface-mount cup to the mounting location, then inserting and locking the tweeter into the cup.
o Flush Mount: Flush mounting is made easy through the use of the threaded flush-mount adapter and plastic locking nut. Once a cutout is made, the flush-mount adapter (with the tweeter installed) is inserted into the hole. The large plastic locking nut is threaded onto the adapter (from behind the mounting surface) to hold the complete assembly securely in place. When flush mounted, the tweeters may be angled for optimum response and imaging.
* Starfish Mounting Brackets: The Starfish mounting brackets allow the tweeters to be installed in factory locations behind the grilles:
o Surface Mount (behind grille panel): Once the Starfish bracket is trimmed, it is screwed to the mounting surface behind the grille panel. Then, the tweeter is inserted into the bracket and locked into place.
o Flush Mount (behind grille panel): Once the Starfish bracket is trimmed, it is dropped into the cutout in the mounting surface behind the grille panel. Then, the tweeter is inserted into the bracket and locked into place.
o Bottom Mount (to grille panel): Once the Starfish bracket is trimmed, it is secured to the underside of the grille panel. The tweeter must be inserted into the bracket and locked into place before the bracket is mounted.
o Flush Mount (in-dash location): Once the Starfish bracket is trimmed, it is dropped into the cutout in the dash. Then, the tweeter is inserted into the bracket and locked into place.
these are what mine looked like out of the box
Old Mar 14, 2006
05reverb's Avatar
I only have the reference series. in your sail panel, there was a screw holding your factory tweeter right? with a plastic running threw it, i'm not sure my tweeter mounts that i got with the infinity's are the same as yours, cause there is no way mine will fit (i think). I would post pick of my mounts, but im too lazy . My mounts are 2 piece, one is a big black ring about 2 inches deep with threads all the way, the other is a gray piece that goes in that black ring and the tweeter goes in the gray piece and the gray piece is held in the black piece by a bold and is adjustable.
Old Mar 15, 2006
LowSky's Avatar
Here's a pick of the tweeter removed
Name:	TWEETER REMOVED.JPG
Old Mar 15, 2006
05reverb's Avatar
yeah thanks man! Ok now i see, u only used one of the infinity mounts, i have 2 peices, so i'll only use the one u used, perfect thanks, exactly what i wanted to see
Old Mar 16, 2006
stepchild's Avatar
I don't remember but I think it would be easier to run the wires from inside the door to out. After you run the wire (either way) you can pull the rest of the wire throught.
Just a somewhat helpful tip. When you mount your tweet in/on the sail panel,try to make the connection of the tweeter accessible behind the sail panel. In case you have to change tweeters,paint grilles or make custom sail panels. This way, in any account you don't have to remove the entire door panel to do these things. I will try to take some pics tonight to show ya. And again I hope this helps.
mistermenphis22
Apr 3, 2016 08:06 AM
ademarco6
Nov 16, 2001 10:19 PM
BabyLX
Nov 16, 2001 05:53 PM
ademarco6
Nov 12, 2001 06:52 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
