can 15'' fit in our car?
Yes, it's an Acura EL
Rep Power: 345 Yep, no problem. I've got a 15" Adire Brahma in the trunk right now, it's freakin huge but I had no problem getting the box in (back when I had a box) and an even easier time putting it into a custom setup. Your main concern isn't getting the sub into the car, it's the enclosure the sub requires.
Rep Power: 253 i have had a 15" solobaric L5 in a ported box in my 2 door before...it took the entire center lineup of my trunk and i had to remove my flat cardboard piece in order to fit it in my trunk and remove it. if you want a pic, just lmk
im sure you could fit 2 15" subs in a sealed box in the civic 2 door trunk. but what good is more subs without the right enclosure eh
Originally Posted by MajinB
yes. your box will be a little spacious though. if you want to save space, drop your spare tire and do a setup in the hole.
Good Idea but your gonna have to make a false floor to raise it a few inches cuz I couldnt fit 12"s in the spare tire well since it wasnt deep enough.
Drunken Master-7thgen Ninja
And i think he ment since its only one sub and not two you can position it better above the spare tire hole. It should fit
Rep Power: 0 my magnet depth was like 6 1/2" and it wouldnt sit low enough. It all depends on the size of the magnet, its cool to do but im just saying you might have to raise the floor depending on the magnet size
one 15 is gonna have a bigger magnet tho so its total depth is gonna be bigger then a 12.
Wall It
Touge
04-26-2015 11:58 PM
Touge
Ottawa
04-26-2015 11:57 PM
aus10
04-13-2015 09:26 PM
