bah, what's wrong with my alpine?
Old Feb 23, 2006
jeez i've only had it a few months and its already crapping out. It is starting to completely freeze for a few seconds on and off at random times. the music turns off, and a few secs later comes back on. sometimes it will do it non stop and other times it will play fine for a few minutes. The deck stays on just freezes. and a few times it froze for 10 secs or more and i could hear the laser seeking the cd and finally it skipped to the next track.
now i've tried a brand new cd even tho the old one wasn't scratched. nothing. i know the amp is fine because when it happens everything turns off (tweets are hooked to deck). It does it stopped, engine off, engine on, and driving. I don't know wtf to do. seems like aftermarket parts have an average life of less than a year these days. so much for alpine quality.
Old Feb 23, 2006
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
i'm sorry to hear you have a problem man, did you hit some bad potholes or has the weather been extremely cold lately maybe either one cracked the laser lens
Old Feb 23, 2006
LowLife's Avatar
LowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to all
dude if it wasn't for bad luck you wouldn't have any luck at all... sorry for the unhelpful response, just suprised again
Old Feb 23, 2006
my car is cursed i already realize that. just wanna fix this problem. yea it did get cold for a few days like 10F but wow i've had my pioneer through 2 winters getting below 0F! i dont understand how the laser lens can just crack. and actually today it was warmer above freezing... didnt hit any potholes either.
Old Feb 23, 2006
LowSky's Avatar
you could have had dirt or something small on the cd you loaded and when the cd started spinning it messed up the lens
try a cd cleaning kit it might help
oh yea gear thanks for the washer nozzle idea
Old Feb 23, 2006
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
Man you have some shitty luck with your car lately. I know exactly how that feels like. Look on the bright side, at least you didn't get hit 5 times in one year like my car has.
Old Feb 23, 2006
hmm well i am always very careful. cds go straight from the burner to the deck or in protective covers. i always look to make sure its clean. and the alpine info says never use cd cleaning kits. should i spray some compressed air? its so annoying having the music cut out. oh another thing i dont even turn the volume up past 10 or 12.
Old Feb 23, 2006
LowSky's Avatar
if its just CD operation then i say try the compressed air otherwise check your warrenty
Old Feb 23, 2006
ya sirius is fine i think. i'll try that. otherwise i have best buy warranty but i'm prolly gonna take it and it will work fine for them .
Old Feb 23, 2006
xvi3tboi69x's Avatar
xvi3tboi69x is an unknown quantity at this point
i guess you wouldnt want to sell it? lol
Old Feb 23, 2006
trust me you wouldn't want it. after it stops playing 10 times a minute you'll feel like pulling out your hair.
Old Feb 23, 2006
lol ill still take it if you dont want it im starting to hate my stock...
Old Feb 23, 2006
7thGenerasianCivic's Avatar
check all connections again behind the deck
Old Feb 23, 2006
well the deck stays on and the connections are soldered and rca to amp. plus i really dont think the connections suddenly are falling apart and then coming back on when the car is sitting still. i tried the air so we'll see.
Old Feb 23, 2006
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
man you have the absolute worst luck of anyone i've ever met. i'd take it to best buy and have them fix it once and for all that way if anything ever happens again you can take it back and be like yeah it broke again so you have to fix it for free. lol haha
anyway i was just thinking about getting an alpine deck the other day. so much for that thought lol.
Old Feb 23, 2006
mrtrinh's Avatar
mrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of light
are you bumping your music loud? or keeping at a low minimal sound? because when i bump my music loud i get the same problem.
Old Feb 23, 2006
EM2 Shinobi's Avatar
EM2 Shinobi is an unknown quantity at this point
gearbox, If you have a multimeter i would check the voltage to the deck, ive had problems with the voltage dropping below 12v and the deck would tweak out, sometimes just reset, from the symptoms you described it could be very likely that could be the problem, or a dirty lens but they are pretty hard to get dirty if your careful.
Old Feb 23, 2006
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
do you have a PSP or PRP? if you have a PRP they will replace it but if you have a PSP.... then either they will replace it if they deem it a "devo" item which means that it is not to be sent out or they will send it out and you will not get it back for another 3 weeks.
Old Feb 23, 2006
sorry guys I am a little retarded. When installing my hood light today, I tapped it off the sirius power wire and well I must have pulled on it a little cause at the battery the connection was almost falling off. so every time i hit a bump or even standing still the sirius receiver would keep resetting (with a few seconds delay from turning off) and that was causing the hu to get confused. I put on a real ring terminal and problem solved. both times. thanks!
Old Feb 23, 2006
Great! i knew it was a power problem somewhere, thats one less thing thats not broke for you.
Old Feb 23, 2006
tripledoublegs's Avatar
Euro-Spec
hehe...good thing you fixed it.
I was starting to wonder when my 9833 will crap out on me...
Old Feb 23, 2006
it connection! woohoo!
Old Feb 24, 2006
runner1738's Avatar
at least it is solved i was gonna say i like alpine decks, but also i was gonna say does it only happen with only burned cds or all cds. but you solved the problem so problem fixed
Old Feb 27, 2006
Scott Civic's Avatar
Racism sucks, just like your Mom...
Scott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of light
Thank God it was just a wire situation! I cruised this forum for months before actually joining and one of the constant's here has been Gearbox advocating aftermarket systems, especially Alpine. I just got the Alpine CDA-9856, mainly because of the advice and praise here over their models, and finished installing it yesterday. You can imagine my terror when I came back and found THIS thread!!! OMG! I wanted to die, all the way up until the last couple of postings! On the bright side, though, it's nice to see that even big shots like Gearbox can make simple mistakes from time to time...
Old Feb 27, 2006
blouisgod's Avatar
Life Begins > 6800rpms
i had a similar problem with my deck. it turned out that the ground wire was coming of the tap after hitting a bump or when it vibrated lose. i love my deck, going on 3 years on weds, alpine 7894 OlDsKooL
Old Feb 27, 2006
mikenam's Avatar
mikenam is an unknown quantity at this point
my deck does the same. i have the 9835. sometimes its playing but i hear nothing. sometimes it just cut completely off. sometimes it plays but the panal isn't displayed its just blank.
hmm..........didn't read the post earlier mabey i should check my ground wires.
Old Feb 27, 2006
you know what, i'm gonna have to blame circuit city on this one too. when they installed my alarm power they used a tiny, crappy ring connector and when i installed the sirius wire i just wrapped it around the alarm terminal. then when i was tugging the wire, it came right out of the connector. i just replaced it with a nice gold plated version
one thing i still want to do this summer is run a dedicated power and ground to the deck so there is no worry about the thin stock wires not providing enough power.
Old Mar 1, 2006
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
heh..was gonna say i can sell you a replacement optical assembly but it looks as though you already solved your problem...
good job...
ricer_em2
May 11, 2016 08:09 PM
speedlever
Sep 24, 2015 07:18 PM
pilebuck13
Sep 21, 2015 10:45 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
