Amp wiring questions
Old Feb 28, 2006
jack123's Avatar
jack123 is an unknown quantity at this point
Hello,
I am going to install a new amp in my car. I was just wondering what the steps are to safely remove and install a new amp (i.e. should ground wire be connected/disconnected first, then power, etc)?
I saw a few small sparks when connecting the power wire to another amp I installed (due to the fact that the power wire was connected to the battery when connecting the new amp). Will this harm the amp? How can I avoid this?
Also, I have read that you should remove the negative ground wire from the battery before connecting an amp. Is this true?
Thanks!
Old Feb 28, 2006
James77's Avatar
James77 is an unknown quantity at this point
Befor you start any work on anything electrucal in your car ALWAYS disconnect the negative cable from your battery. If you wanted to make extra sure remove your in-line fuse from your amp power cable. Then you wont get any sparks.
Old Feb 28, 2006
performance sys's Avatar
performance sys is an unknown quantity at this point
Best advice around. Disconnect the negative from your battery, do all of the wiring, then reconnect the negative as the last part of the installation.
Old Feb 28, 2006
jack123's Avatar
Done....
I disconnected the negative terminal from my battery before connecting my amps. However when I reconnected the negative battery terminal at the end of my install, I noticed a few sparks as I made the initial connection to the terminal. Is this normal?
Old Feb 28, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
screw wires
Old Mar 1, 2006
Originally Posted by jack123
Done....
That's normal.
roverben
Jan 21, 2019 05:16 PM
jackoncruzpr
May 24, 2015 12:24 AM
pincookie1
May 4, 2015 12:22 PM
viper775
Dec 9, 2001 10:52 PM
klam
Nov 16, 2001 03:36 PM
