Wiring neon to come on with amp
Old Feb 21, 2006
Quantas's Avatar
I HEART KATIE
Quantas is an unknown quantity at this point
i was wondering if i could tap the remote turn on for my amp to also turn on my neon for my trunk, does the remote turn on send a constant +12V from the HU or is it just a one time "ping" to the amp to turn it on?
Old Feb 21, 2006
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
its DC...so its constant..
Old Feb 21, 2006
Quantas's Avatar
I HEART KATIE
so the remote turn on is always on when the HU is on?
Old Feb 21, 2006
paradoxblue's Avatar
or attach it to your trunk light. like i did so its only on when trunk is open..
Old Feb 21, 2006
eye_see_you's Avatar
let the devil out
you could wire it to a relay or switch
Old Feb 21, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
yup, but most remote turn on lines only support half an amp of current at the most. if your going to use it to control your neons, you need to use a relay.
Old Feb 21, 2006
Devani's Avatar
yupp.....what he said....when you put the key in accessary position to be exact....
since you are putting in your trunk...it will not be a big size I assume...
if your neon draws alot of current you will need an relay but since I am assuming that it is going to be okay size, you won't need relay...cause you will be gettin main power from elsewhere..
Old Feb 21, 2006
not if hes using the amp turn on wire.
Old Feb 21, 2006
Devani's Avatar
DUDE RELAX.....
Geez
Old Feb 21, 2006
Devani's Avatar
double post please delete..
Old Feb 21, 2006
Quantas's Avatar
I HEART KATIE
actually i have a CCFL (Cold Cathode Flourscent Light) that i want to put in the trunk, its made for computer cases, but i used them before in my G20 before i got rid of it, its only like 12 inches long and i want it to either be on when the amp is on, or ill wire it to a switch that will control 2 that im going to put under the dash too...
Old Mar 1, 2006
Quantas's Avatar
I HEART KATIE
bump...anyone?
Old Mar 1, 2006
whatya need help with?
Old Mar 2, 2006
MegaHurtz's Avatar
Just because it's DC does not mean it is constant
Personally I would say wire it with a relay, although if it's just 1 light you could just grab the power for it from the remote wire, although I wouldn't recommend it.
Old Mar 2, 2006
diskreet's Avatar
I am so glad that computer engineers (my major) get lots of electronics classes and I will never have to ask about stuff like this.
no offense to whoever posted this, its just nice knowing what you are doing when it comes to electrical circuits!
Old Mar 2, 2006
realitycheck's Avatar
realitycheck is an unknown quantity at this point
Hey Quantas that cold cathode light runs off of ac power right? Since its in a computer case, it wont run on dc also will it?
Old Mar 2, 2006
diskreet's Avatar
CCFLs (Cold Cathode Flourescent Lamp) themselves run on AC power. But 99% of ALL CCFLs sold commercially (not as a unit right from manufacturer) have a DC to AC converter and thus require ~12v DC. Which is what they run off in your computer case, and also in the car.
So the CCFLs in computers are basically exactly the same as those for cars with a different connector (Molex connector for PC, 12V accessory cig lighter connector for car)
Old Mar 3, 2006
shmik1's Avatar
i say just wire it to a switch or ur trunk light..
Old Mar 4, 2006
Quantas's Avatar
I HEART KATIE
i was thinking about wiring it to a switch but i thought it would be cool if the remote turn on also had the light on as well as the amp so if for whatever reason i wanted to turn my HU off while driving the light would also turn off... and yes the CCFL did come with the AC to DC adapter which makes it run off ~12V
sch2cm
Jul 21, 2015 09:58 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
robbie374
Jul 7, 2015 02:56 AM
