Sound System
Old Feb 20, 2006
djrabbi's Avatar
djrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to all
Sound System
wassup,
i have a 05 civic special edition.... and im gonna get a decent system, heres a pic of it
so my question is what kind of wiring would i need for all of this???
heres the specs:
* AMPLIFIER
o 400 X 1 WATTS RMS
o Brushed Aluminum Chassis
o Top Mount Controls with Blue Illumination
o Cooling Fan
o Chrome Dub Fan Grille
o Doublesided Glass Epoxy Circuit Board
o PWM MOSFET Power Supply
o THD: 0.02%
o S/N Ratio: 100 dB
o Frequency Response: 10Hz - 40kHz
o Variable 18 dB Hi-Pass Crossover: 75Hz - 750kHz
o Variable 18 dB Lo-Pass Crossover: 50Hz - 150Hz
o Selectable Bass EQ
o 4-Way Protection Circuitry: Thermal, Short Circuit, DC Offset, and Overload
* 10" SUBWOOFER
o Oversized 30 oz Double-Stacked Strontium Magnet
o Power Handling: 200 Watts RMS
o Frequency Response: 24Hz - 1kHz
o Efficiency: 87 dB
o 1.5" Foam Surround
o No-Press Pulp Cone
o 1.5" 4-Layer ASV Voice Coil
Old Feb 20, 2006
SPUNKYcivy01's Avatar
SPUNKYcivy01 is an unknown quantity at this point
400rms, eh? If I were to put those in my car, Well, I would go with an 8 or 16 guage wiring kit that goes from the battery to the amp. If a professional were to install it, it would be about 75 bucks for wiring as well. You are going to need RCAs as well, that go from the deck to the amp. These run for about 35 dollars and can be installed professionally. If the deck is stock, you will need to do it a different way, I am not sure how because most stock decks do not have RCA outputs. Hope that helps
Rob
Old Feb 20, 2006
oh yeah, you will need to bridge the amp as well bc you have a mono amp and two subs, this will also maximize power, so get some speaker wire too.
Old Feb 21, 2006
djrabbi's Avatar
yeaa circuit city said around 150 to install it, but thats without wiring. soo i just wondering
Old Feb 21, 2006
diskreet's Avatar
son of a bitch you made 3 of these threds?
Old Feb 21, 2006
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
hahahaha
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
nufc
Legal Questions and the Law
Jun 21, 2015 09:57 PM
Jeffdp
Jun 18, 2015 06:18 PM
BabyLX
Nov 16, 2001 05:53 PM
JDock
Nov 9, 2001 08:53 AM
