Hardwiring a certain radar detector....V1
Old Jan 27, 2006
P.O.S.B.A.S.04's Avatar
Ever Wonder What P.O.S.B.A.S. Is An Acronym For
P.O.S.B.A.S.04 will become famous soon enoughP.O.S.B.A.S.04 will become famous soon enough
Talking Hardwiring a certain radar detector....V1
alright, i have this gorgeous Valentine1 radar detector and i want this biznatch hardwired in! the hardwire kit includes: a relay, a fuse (for the fuse box), a wire clamp. i have no idea what in the h311 to do with this stuff!
if i am stick the fuse in the fuse box, where do i put the wire clamp (on which wire)?
thanks for the help!
here are some pictures to show you what i am working with...
Old Jan 27, 2006
spudracer326's Avatar
spudracer326 is an unknown quantity at this point
i would just have i installed. its not that much maybe 25 bucks. then you get a warrenty on the install.
Old Jan 27, 2006
CenZ's Avatar
PWIT
cant you just cut the end, and wire it into something like the cig lighter, that way it works when the car is on and then when you turn it off the radar detector turns off too...
Old Jan 27, 2006
i don't know...that is wht i am trying to figure out. the thing is the V1 works with a different wiring than normal radar detectors, it uses your typical phone line cord that you plug into the wall so i think splicing is out of the question!
Old Jan 27, 2006
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
it has a phone cord plug that goes into the dector right? Just like the Passport 8500 or X50. On mine I cut off the cig part of it and just wired it up under my steering counsole...
If that direct wiring kit just plugs into the V1 then us a DMM to figure out which wire either under the steering wheel/ behind the radio has power in the ON position and then just wire it accordingly
carid
Aug 8, 2015 05:05 PM
AirJordan613
General 7th Gen
Aug 2, 2015 08:55 PM
RyzRocket02
Oct 30, 2002 10:16 PM
1028CiViC
Aug 1, 2002 11:19 AM
civicdeveloper
Jul 18, 2002 09:54 PM
