Can I reupholster my sub box?
Old Jan 25, 2006
Cptn. Slow's Avatar
Formerly efil on evol on
Cptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura about
I searched "reupholster" and nothing came up.
Is there anyway that I can take my sub box apart, reupholster the panels, and then put it back together. In theory I could, but the glue is the only thing I'm not sure about.
The reason I'm asking is I reupholstered the carpeted trick door floor I made with black vinyl and want the box to match. I have thought about making a new box but I really don't want to waste my current one when it still sounds great.
If you pics would help jsut ask
Old Jan 25, 2006
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
Just rip the carpet off. Then put new carpet on.
Old Jan 25, 2006
manahoonie's Avatar
/\/\ maybe sand the sides some to get some of the old glue off...
Old Jan 25, 2006
eye_see_you's Avatar
let the devil out
#m gspray on glue , some staples or tacks for some spots sometimes and go to work
Old Jan 25, 2006
Cptn. Slow's Avatar
thanks guys. I had not looked at it from the stand point of not taking apart, but now that I did I think it will be possible
Old Jan 25, 2006
MegaHurtz's Avatar
you don't need to take your box apart, just rip the carpet off and put the new material on
Old Jan 25, 2006
Cptn. Slow's Avatar
I'll try and get it this weekend while I have everything tore apart putting adding new amp
Old Jan 26, 2006
PopcornPlaya's Avatar
Electric Boogaloo...
Don't waste your money on the expensive 3m spray clue, the lower line works just as well. Personally, I use HVLP grade contact adhesive and spray it on with an air sprayer, but one box doesn't justify buying everything to do that.
Check the DIY in the sticky about carpeting for some helpful tips as well.
http://www.7thgencivic.com/forums/sh...ad.php?t=93078
h4ldol
Apr 24, 2017 08:16 PM
Raiool
Oct 1, 2015 10:42 AM
Hutch1051
Sep 29, 2015 09:20 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
h4ldol
Sep 17, 2015 01:25 PM
