How to get sound from my xbox
Old Jan 23, 2006
allstarsardar1's Avatar
allstarsardar1 is an unknown quantity at this point
I did a search and got alot of pages to try and look through, did what i could but still cant find an answer...i want to know what i need to buy in order to get my xbox's sound to work with my stock headunit? im sure someone else has done this before so if someone could point me in the right direction that would be great
Old Jan 23, 2006
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
I think its PAC or Peripheral that makes it, its an auxilary input for Honda's, I believe the model number is HON-AUX or something simple like that.
What it does is plugs into your factory headunits CD changer port, and gives you a pair of RCA inputs, so you can plug the RED/WHITE audio cables from your XBOX directly into the headunit.
I think the unit is about $50 or so, maybe cheaper on the net.
Old Jan 24, 2006
performance sys's Avatar
performance sys is an unknown quantity at this point
If your headunit has CD changer controls, I have an auxilary input box that will plug into the back of your stock headunit with two RCA plugs for easy connection. Will only work on 2003 or before Civics, and you cannot use the Honda CD changer or XM attachment at the same time as this aux box.
$69.99 for the aux box + $7.99 for the proper cable.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
2005seTO
Aug 18, 2015 12:45 PM
CraigW
Aug 18, 2015 07:06 AM
BootyDo
Jul 26, 2015 10:38 AM
Hqly2001
Jul 25, 2015 05:32 PM
