headrest
Old Jan 22, 2006
kumanan's Avatar
kumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the rough
headrest
I got a 2003 civic with those square headrests.. the one with the square holes in them... like the middle is empty.. if you know what i mean... its an Si. Anyways i got 7'' hearests... can the headrests be installed in them? Or can i get another headrest thing where i can get it custom fit into... liek another Civic model... let me know thanks
Old Jan 23, 2006
MegaHurtz's Avatar
the sedan has solid headrests I do believe, but I'm still not sure if they are big enough for 7" screen to fit
you could always experiment with cutting a piece of foam to fill the hole, as it wont be seen once you re-upholster
Old Feb 16, 2006
kumanan's Avatar
ne one
Old Feb 16, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
hold the screens bezel up to the headrest to see if itll fit. If you want to keep the coupes headrest your going to have to have them reupholstered
Old Feb 17, 2006
holokaustos's Avatar
holokaustos is an unknown quantity at this point
Originally Posted by MegaHurtz
the sedan has solid headrests I do believe, but I'm still not sure if they are big enough for 7" screen to fit...
The 04 EX sedan has the solid headrests, but it looks like 7" might be too tight of a fit. Is your 7" the full size of the monitor or just the viewable area? If the 7" is the viewable area, then the trim of the monitor will be larger and might not fit the headrest...
http://tinypic.com/view/?pic=nyy6uf
Dawit Melese
Sep 11, 2015 08:25 PM
SSSS
Jun 2, 2015 01:46 PM
AlpineCivic
South Cali
Jul 29, 2004 06:20 PM
civic01vtec
Mar 18, 2004 07:28 PM
TheICON
Oct 15, 2003 11:40 PM
