Need Help - Problem with stock head unit
Old Jan 13, 2006
slik_gts's Avatar
slik_gts is an unknown quantity at this point
Hi, I just got a used factory head unit (cd player) for my 01 civic and it says code 1 on it. Every time I press a button it says error and the anti theft light keeps blinking. How can I fix this problem? thnx for your help in advance!
-Fahad
Old Jan 13, 2006
Echelon04's Avatar
The one and only....
Echelon04 is an unknown quantity at this point
You need to enter in the security code. Who did you get it from?
Old Jan 13, 2006
ya it needs the code to turn on. whoever you bought it from should have it
Old Jan 18, 2006
slik_gts's Avatar
ok i got the code from the dealership...however there is no sound coming at all, no static either. I have no idea why. I plugged in my aftermarket headunit into the stock wire harness and bam the sound was there. As soon as I plug in the factory unit, the sound goes away; i turned the volume all the way up and still nothing. Any ideas why this might be and how can i go about fixing this. thanks in advance guys.
-fahad
Old Jan 18, 2006
turn up the volume. edit nm deck is dead
Old Jan 18, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
-fahad
the decks toast did you buy it used?
Old Jan 18, 2006
slik_gts's Avatar
yes i did and that was $60 down the drain. dammit!
mugenca
Apr 16, 2015 12:15 AM
PimpBot5000
Nov 26, 2001 07:15 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
