Alpine d900 install help
Old Jan 9, 2006
gnat1000's Avatar
gnat1000 is an unknown quantity at this point
I know a few people have installed these on their cars. My question: is there an easy way to connect the brain to the wire harness without running long wires from every individual wire? I'm thinking of installing the brain under the driver seat but it looks like I would have to run wires for every color from the brain to the wire harness. Is there anyway to bypass that? Thanks
Old Jan 9, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
well if your amping everything youll only need to run a few wires
Old Jan 9, 2006
gnat1000's Avatar
yeah i'm installing 2 amps and a sub as well. I also got to figure out how to install that video bypass. Any help on that would be great too.
Old Jan 9, 2006
MegaHurtz's Avatar
no help on installing video bypasses in here
if you are running 2 amps, why would you need to run anything more than accessory, 12v and ground and power antenna wires to the harness?
Old Jan 9, 2006
gnat1000's Avatar
i was just thinking about running the speakers through the harness instead of running them through the amp
Old Jan 9, 2006
you can always use the factory wiring, but why bother? Sounds like your going to have your car apart allready, pulling wire through the doors isnt that big of a deal.
Old Jan 9, 2006
MegaHurtz's Avatar
so then you are considering only running just an amp for the sub?
my advice, use the second amp as well, you obviously dropped big cash on the d900, might as well go all the way, if you gotta do it, do it right.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
