Polk 6 1/2 component speakers
Old Dec 28, 2005
03CivicEX4Door's Avatar
03CivicEX4Door is an unknown quantity at this point
Just installed my polk component speakers, I have 2 queston's. 1 where's the best place 2 mount the tweeter's? 2 has any one installed these speakers in their vic cause the door pannel won't go on all the way it's binding on the speaker i think something need's trimmed i was just wondering if any one knows how to fix the problem.
Old Dec 28, 2005
jttegx's Avatar
OMNES AD UNUM
1) its hard to say "best" because theirs the best sounding location and the best mounting for easiest work. but if you have the factory tweeter pods on the civic, use those. sound perfectly fine on my civic.
2) i have the polk db's component 6.5" set in the civic when i had it, they fit peffectly fine using the factory tweeter pod location. all that pod/mounting hardware the components came with...i just threw it back in the box.
but if your having trouble with fitting the 6.5" woofer on the door panel location, you may need spacers as i did.
Old Dec 30, 2005
i'm having problem, The mounting heigth is a little over 1/2. The tweeter will hit the factory grill. Is their i way i can make it work?
Old Dec 30, 2005
EssEss21's Avatar
EssEss21 is an unknown quantity at this point
cut the inside of the facory grill?
Old Jan 10, 2006
chrisavs's Avatar
chrisavs is an unknown quantity at this point
I just mounted my tweeters yesterday on the little triangular plastic piece adjacent to the rear view mirrors. Just run the wire down the inside of the door and connect the wire to a coat hanger and poke a hole in the rubber stuff that insulates the other wires and run it into the car that way. I also put my crossovers like right under the seat but mounting them on the sides of the center console would probably look pretty sick. Good luck.
Old Feb 8, 2006
thatsmrgimp2u's Avatar
An elephant.... with stamps for hands.
thatsmrgimp2u is an unknown quantity at this point
Any pics of mounting locations in a dx? for the tweeters that is.....
Old Mar 16, 2006
PiNoYxRaCeRxRH's Avatar
PiNoYxRaCeRxRH is an unknown quantity at this point
crossover mandatory? and if i do put the crossovers on does that mean i have to change the factory wiring?
Old Mar 16, 2006
James77's Avatar
James77 is an unknown quantity at this point
You will need either a cross over or a cap to prevent the low frequencies from getting to the tweeter, otherwise you will blow it.
Old Mar 16, 2006
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
theres a big block of foam on the inside of your door... take that piece of foam out... doublesided tape the xover to that area and your good to go..
Old Mar 16, 2006
C-Mo's Avatar
C-Mo is an unknown quantity at this point
I bought tweeter mounts from the dealer for $30 that fit a 2000 coupe. I screwed and bondo'd the ones from my car to the ones I purchased. They work out great! I just have to repaint them cause a little miscalculation of paint thinkness on my part oops!!!
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Islesfan
Sep 29, 2015 03:42 AM
Gsxtacy
Sep 12, 2015 01:09 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
