right door powerlock!
PWIT
might be the electronic acculator on the door the little thing with three bars on it, there should be a thing on the bottom of it with plugs going into it. that might no work anymore.
how much do they run? and where can i get one? i can't seem to find any on the internet. (i'm sure dealership can order one, but that would be my last option).
PWIT
junk yard, its prolly the same for a sedan and coupe. the accual locking system will be different but thats not your problem. the little electronic on the bottom of the locking system is what you want.
Would this be covered under warranty? I have an 01 and got the extended warranty and am having this problem. Plus i'm lowered. Would the stealership try to blame this for the problem?
Slowest 7thgen in the GTA
I have this same problem too. It only happens to me in the winter though. Never happens in the spring or summer.
What I do is play around with it, and it usually ends up working again. I know I should get it fix, but I don't think I really care that much. I might end up going to the dealership and try to get it fix under warranty.
PWIT
Originally Posted by grenloch101056
if they do tell them their a bunch of (_o_)'s. They have to prove the modification caused the problem before voiding your warrenty
http://www.7thgencivic.com/forums/sh...36#post3484636
this is the DIY for replacing the door lock actuator.
redcloud
Sep 7, 2015 01:45 PM
ballmich
Jul 9, 2015 11:59 AM
