HELP: Removing stock door panel speaker from its Frame.
Old Dec 22, 2005
Hippiboy's Avatar
Hippiboy is an unknown quantity at this point
I need to use the stock door panel frame to install my Kicker KS60. Do the speaker and the fram come off or do i have to cut it out? If i have to cut, is there a site where i can just buy the frame?
thanks
Old Dec 22, 2005
Zeppelin8778's Avatar
Zeppelin8778 is an unknown quantity at this point
ok, the speakers in the doors are held in with clips. i had trouble with this the first time i got mine out. Take a screw driver and stick it in the little slot on the top of the speaker and push down (this pushes down on the silver clip holding in the top) and then pull the top of the speaker out and down. keep pushing with the screw driver in different spots at different angles until it comes, u have to get it just right. Im sure u will figure it out.
Old Dec 22, 2005
manahoonie's Avatar
no, what i think he's talking about is he wants (apparently 'needs') to use that plastic frame that the speaker is connected to again. why not get the aftermarket speaker adapter? they're usually on ebay...
Old Dec 22, 2005
oh i gotcha... yea i thought he meant the metal frame of the door, not the plastic speaker frame... uhhh all i needed for my door speakers were the HONDA adapter rings that CAME WITH the alpine speakers i bought. also i had to cut away part of the door sheet metal to make the hole a circle instead of that little weird oblong shaped hole. i didnt really have a saw so i just used a drill and drilled a bunch of huge holes in the part i had to cut away, then hit them with a sledge hammer a bunch until it sorta bended back. It sounds clear and totally unmuffled so i suppose it worked.
Old Dec 22, 2005
Hippiboy's Avatar
Ok guys, thanks for the input. I just ordered some adaptors from crutchfield. they have amazing number items.
Old Dec 23, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
You were referring to baffles. They're also referred to as specers. I'd have recommended cutting them from some scrap MDF or other wood lying around. It saves you money and is very easy, plus you can cut them any depth you want.
Old Dec 23, 2005
usafcushman's Avatar
7thGen's Loudest Civic...4,000 watts and climbing...
usafcushman is on a distinguished road
i used 3/4" MDF to make mine, and i was running KX60s, so that should work for you as well...
Old Dec 23, 2005
blouisgod's Avatar
Life Begins > 6800rpms
yeah, a spacer may not work depending on how deep the driver is. you may have to cut the area as well, which is most likely the case.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
MamaBear2015
May 18, 2015 07:37 PM
timpan
May 18, 2015 07:06 AM
MamaBear2015
May 3, 2015 02:17 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
