switch install
Old Dec 18, 2005
Imtheconvict's Avatar
Imtheconvict has a little shameless behaviour in the past
switch install
im Puttin a switch on my remote turn on wire so i cant choose when i want it on or off. Im thinking about putting in 1 of the 2 empty spots next to the cig lighter do they just pop out? and what do you use to cut them
Old Dec 18, 2005
mrDFWmechanic's Avatar
those slots should just pop out
Old Dec 18, 2005
manahoonie's Avatar
yeah, pull off the cig lighter panel, and they can pop out, or you can use a small flat head screw driver, and pry it out from either above or below the rectangle piece.
Old Dec 18, 2005
clrumivier4life's Avatar
clrumivier4life is an unknown quantity at this point
That's where I put some switches. I had my console out at the time so I just pushed them from the back to get them out. I drilled some holes and stuck them in and wiring wasn't too bad since I had the console out.
Old Dec 18, 2005
MegaHurtz's Avatar
The covers just come out, use a drill
I put some in under the dash on the driver's side, out of view
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
SuperEF
Jun 24, 2015 11:53 PM
RIPSAW
Jun 9, 2015 08:33 PM
brian257
Jun 4, 2015 08:17 PM
nickfn
Nov 8, 2001 09:44 AM
