Good Choice?
Old Dec 22, 2005
  #31
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
Originally Posted by 04hemiboy
Obviously your Pioneer is an exception.I had the Premier P860mp in my truck,and i got the alpine 9855 in the civic and the SQ and feel of the deck is alot better than the cheap plastic pioneer.But i'm sure the alpine F1 will give that stuff you got a run for the money.
LOL...yeah, i'll give you that one (alpine f1)! good call.
Old Dec 22, 2005
  #32
04hemiboy's Avatar
04hemiboy is just really nice04hemiboy is just really nice04hemiboy is just really nice04hemiboy is just really nice
There now we agree... MERRY CHRISTMAS you have extremely nice equipment.
Old Dec 22, 2005
  #33
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
has n e one had any actual experience with this deck? it has adf (automatic distotrtion filter - i think) and when i turn it on level 1 or 2 it get WAY WAY WAY bassier and just sounds muddy...i'm sure if i re-tune the amps with it on it'd sound better, but right now i just have it off with everything tuned the way i want it...anyone know if it'd be better to use adf and to tune my amps to that?
Old Dec 22, 2005
  #34
04hemiboy's Avatar
It's basically the same thing as Media Expander on the Alpines.It boosts low quality in the MP3's.Just tune your amps with it off.Then if you play some Mp3's with a sh1tty recording then adjust it from there.
Old Dec 22, 2005
  #35
booba5185's Avatar
i figured, also, after i installed this deck, if i listen to my system for short periods of time (on my 15 min break at work) it KILLZ my battery....there's 2 things i thought of, 1 i have fixed, first fixed one, i upgraded the ground on my amps to 4awg (the same awg as power now, they were 8awg) along with upgrading the wire that goes from the battery to relay box under the hood to 4awg. the second that i havnt fixed is the deck has 2 12volt in's one that is supposed to goto the battery and one that is just supposed to go to the internal constant power (on a side note the one that DOESN'T goto the battery has a 15a fise, while the one that does has a 3amp, y?) but right now, they're both running off the normal constant under the dash, i have a lot that needs to goto the battery, so i'm gonna run another install kit with a distribution block and split off from there (this deck, tach, power windows,,etc.) any ideas?
Old Dec 22, 2005
  #36
MajinB's Avatar
Drunken Master-7thgen Ninja
get a high output alternator.
Old Dec 23, 2005
  #37
HondaSales's Avatar
yes, now we agree. thanks for the compliment on my ICE however, i sold the civic and bought a tsx. the system was beautiful though and i miss it! you have a merry christmas as well!
Old Dec 23, 2005
  #38
HondaSales's Avatar
sounds like you may need a high output alternator but i would try an optima yellow top first. when i had that problem, i did the alternator first but my problems were not solved until i bought the deep cycle battery. good luck.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
