why isn't this working?????
Old Dec 22, 2005
I have a brand new alpine AINET/MBUS cd changer. I have a brand new alpine RF modulator with MBUS, and I have an ainet to mbus conversion cable. The changer is set to mbus mode and I'm trying to install it in an old accord that has a stock tape deck. When I plug it all together, it gives me an error code changer not connected on the display screen. wtf do i need to do to make it work?
Old Dec 22, 2005
82801BA's Avatar
82801BA is an unknown quantity at this point
Because you can only use Ai-Net to control M-bus, not the other around.
Can you let me know what model the change is? And let me know how you actually connect it?
Old Dec 22, 2005
okay i got worked up over nothing. having no instructions, I found some on alpine site and it turns out there is a tiny reset button on the fm mod that needs to be pushed. Now it is working perfectly! I have the latest alpine ainet changer mp3 6disc. it has a switch to use either mbus or ainet but the cable is ainet only. so i needed a conversion from ainet to mbus so i could then plug in the mbus to the rf modulator. it all worked afterall.
Old Dec 22, 2005
catalin's Avatar
catalin is an unknown quantity at this point
Doesn't the accord deck have a CD button? If it does then you can plug it all in the deck without the modulator.
Old Dec 23, 2005
MegaHurtz's Avatar
yeah but he drives a civic
btw, surrey WHAT
Old Dec 23, 2005
catalin's Avatar
Guildford... Civic and Accord tape decks from about 93 to 98 were able to control Alpine M-Bus changer with a minor modification.
Old Dec 23, 2005
okay if anyone didn't bother to read the other posts, I am installing into an 92 ACCORD with factory tape deck. No it doesn'thave any cd button or extra connection in the back. Tape only. Again I already got it to work so thanks anyway.
Old Dec 23, 2005
catalin's Avatar
I read it.. Just thought I'd mention because some people don't know that the Honda decks will control the Alpines.
Old Dec 23, 2005
i meant megahurtz he should know better haha
Old Dec 23, 2005
MegaHurtz's Avatar
Fleetwood/Guildford
ORskier
May 3, 2015 12:54 PM
alexkharden
Apr 23, 2015 07:13 PM
cooldan1
Apr 23, 2015 10:49 AM
ashleymmackey
Apr 18, 2015 09:48 PM
