JL 12W3V2 Sub Rumbling problem...
Old Dec 8, 2005
greenmeansgo's Avatar
greenmeansgo is an unknown quantity at this point
Question JL 12W3V2 Sub Rumbling problem...
Hello all,
I Have a:
Rockford P6001 amp
JL 12W3V2 sub
Pioneer deck
2004 Civic SI
If i run this system in when my car is off (turn key to accessory position) it seems to work ok. As soon as I start the car, I get this weird rumbling comming from the sub, the loudness depends on the volume/gain setting on the amp. Even at low volume / amp gain the rumbling is very noticeable.
In both cases I am playing a CD (hip/hop & rap)
My sub is wired correctly for 2 ohms and the polarity from the amp to sub is correct.
I tried disconnecting my rear speakers and it does not appear to have any effect.
I also have 2 12" sony xplod's and they run perfectly (single voice coil i believe).
Anyone have any clue what is causing this?
I am puzzled
Thanks for your help.
Old Dec 9, 2005
eye_see_you's Avatar
let the devil out
the low rumble you have sounds familiar to a defective DC regulator in the AMP itself. I had the same issue and thats what it turned out to be. pull your rca's from the amp to see if it still does it just to rule out interference
nirvanaguy
25
Oct 26, 2017 07:26 PM
Juanb24
Sep 15, 2015 12:39 AM
Mannimarco
Sep 7, 2015 10:01 PM
alaga
25
Aug 13, 2015 04:42 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
