2nd capacitor or high amp alternator?
Old Nov 28, 2005
jayjdlc's Avatar
jayjdlc is an unknown quantity at this point
hi to everyone! i have a JL amp 1000/1 connected to JL 10w7 and JL amp 300/4 connected to my 4 speakers inside the car. i have one capacitor but the headlights still dim. what should i do?? would it solve my problem if i buy another capacitor or change my alternator? if i have to buy another capacitor, what brand? if i have to buy an alternator, where can i buy one?
thanks for reading this thread and hope you can help me.
Old Nov 28, 2005
eye_see_you's Avatar
let the devil out
I had a jl 300/4 and jl 500/1 hooked up on my alumapro 5 farad cap and occasionally had lights dimming, I even had a altima yellow top instead of the stock battery. My best sugesstion would be to tune your amps properly and maybe add a second cap or one large cap instead.
Old Nov 28, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
HO ALT... or 3 1F caps and a yellow top
Old Nov 28, 2005
MegaHurtz's Avatar
just get a good battery and you should be fine
more caps is the LAST thing you should ever have to do
Old Nov 28, 2005
fiatdale's Avatar
fiatdale will become famous soon enoughfiatdale will become famous soon enough
In my trucks system I have 2 yellow tops, and an Alumapro 15 farad, but then again it also has a 170 amp alternator. Id say put a Yellow Top in, and maybe a bigger cap.
Old Nov 29, 2005
ruckerheadz's Avatar
ruckerheadz is an unknown quantity at this point
get rid of the cap, and forget adding a bigger or more of them all its doing its causing more draw on ur electrical system to keep them charged up. first get a bigger battery kinetic, svr, stinger, odyssey, gnb the list goes on and on, and dont listen to the kids tellin u optima unless ur runnin it alone for the stereo only. look for sumthin over 2000cca drycell and if u still have problems then look into upgrading to a bigger amperage alt, when u do look for sumthin over 200amp atleast, its better to go a lil to big then not enough and the difference in price isnt worth redoining. just my 2cents hope it helps
Old Dec 2, 2005
yourpalmike's Avatar
yourpalmike is an unknown quantity at this point
nice
nice
cukaracha
30
Jul 26, 2015 12:01 PM
mistermenphis22
Jul 13, 2015 04:43 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
jackoncruzpr
May 24, 2015 12:24 AM
