Vibration in driver's door speaker
Old Nov 24, 2005
Roosbok's Avatar
Roosbok is an unknown quantity at this point
I get a very annoying buzzing from the driver's side door speaker. When I put pressure on the plastic in the area to the upper left of the speaker holes to push the inside door panel with the plastic of the door pocket (they are separate pieces) the buzzing goes away. Does anyone have an idea of how to permanently eliminate the sound? Will I have to remove the door panel to look at the speaker? Thanks.
Old Nov 24, 2005
eye_see_you's Avatar
let the devil out
I put brown bread on my whole interior door panel and it cut down on the vibration I had. Try and make sure that all your clips snapped back in also
Old Nov 24, 2005
SOHC's Avatar
I spent 1425 points to do this.
SOHC is an unknown quantity at this point
ive got the same prob with my passenger side on my 01 coupe.. sux
Old Nov 24, 2005
CraigW's Avatar
The mechanics at the dealer use strips of wool felt to quiet the rattles.
Old Nov 24, 2005
spudracer326's Avatar
spudracer326 is an unknown quantity at this point
your speakers probably werent installed right. you have to buzz down the round thing on the inside of the door panel tht seals the stock speakers to the door panel. Had the same problem and this completley eliminated it.
good luck
Old Nov 25, 2005
MegaHurtz's Avatar
Make sure the speaker is properly secured into your door and hasn't come loose.
Old Nov 25, 2005
Roosbok's Avatar
I suspect the problem is something like that. It has been there from nearly the time I bought the car. I tried pulling the door panel off, but it wouldn't budge and I don't have the tools or knowhow to do the job. The Civic seems to be the car for people who find it challenging to seek find and solve the workmanship problems that came with it from the factory. Unfortunately, I do not seem to be one of those people.
Old Nov 25, 2005
Ed's Avatar
Ed
I know there's a service bulletin out for our gen for the door rattles. All the dealers do is remove the door liner then cut little strips of the self adhesive wool felt as stated above and stick them to the protruding ribs on the inner liner. Often, it's just the ribs on the liner hitting the metal of the door frame. If you can spend a few hours and get the panel off, getting rid of the rattle should be no problem.
You can get entire sheets of wool at any fabric store, by the felt square section.
And, of course, always check the speaker clips and all that as well.
Good luck! report back when you're done
Ed
Old Nov 25, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
it doesn't take ours to take the door panel off, but on mine, the plastic rivets broke and i just super glued them back together and the rattles went away.
Old Nov 25, 2005
Ed's Avatar
Ed
well, not hours to take it off, but a couple hours to take it off, put stuff on, try it and do it all over again if the rattle doesn't go away, which it never seems to on the first try
Old Nov 25, 2005
booba5185's Avatar
lol, after putting 3 sets of new speakers, running new speaker wire through the whole car, putting power windows and power locks in, re-carpeting the doors, changing the door handles and cutting the linkage for the locks, i can get that baby apart in less than 3 min.
Old Nov 26, 2005
Roosbok's Avatar
For the time being I have adjusted the balance a few settings down for the left and up for the right speakers. This seems to eliminate most of the buzz. Maybe someday I will figure out how to get the door panel off.
Old Nov 26, 2005
mine was terrible and its the spots where that pocket meet the panel. you can shove foam pieces inbetween the pocket and door on each side without taking anything off.
Old Dec 2, 2005
yourpalmike's Avatar
yourpalmike is an unknown quantity at this point
try dynamat. its expensive but it works...
Old Dec 2, 2005
booba5185's Avatar
or fatmat
Old Dec 3, 2005
that won't work for rattles, unless you stuff it between the plastics that are touching. dynamat is only for sound deadening the metal to make it seem denser than it really is. Has nothing to do with rattle.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
mohawkboom
67
Aug 25, 2015 12:28 AM
Jeffdp
Aug 5, 2015 11:38 AM
Youngciviboy
Jun 10, 2015 03:49 AM
Macko
Exterior
Nov 19, 2001 10:34 PM
