rear defrost is messing with radio
Your antenna and your rear defroster are both built into your back window. Look at the lines on the window for any scratches or breaks, and at the sides where the connections are made.
A good glass repair shop should be able to fix any breaks or scratches you find without having to replace the rear window.
I don't think the window tinting would help reception at all. more likely than not, after the tinting job, some connection was put back in place, be it the connections of the side or on the window it self.
I'd first do what the other people suggest and check the connections from the back of your HU to the rear window.
OptimisticWay
46
Oct 15, 2015 02:16 PM
Dave1984
Jul 22, 2015 06:10 PM
Causemo
Jul 4, 2015 07:11 AM
