Metra and Alpine fit fixes? other decks with fitment issues with the metra kit?
Old Nov 13, 2005
k-man's Avatar
k-man is an unknown quantity at this point
I recentely purchased and installed an Alpine 9855 and used the Metra kit which allows for the pocket to be retained, now the problem is that when using this kit the alpine decks dont line up to the existing mounting holes on the bracket that holds the deck/pocket, so the cage basically supports the weight of the deck and causes it to stand downwards.
Is there a fix for this? I know others will alpines have had the same problem.
I was thinking of making new holes in the bracket so i could screw it in or put something in between the pocket and the deck so it sits straight.......I was thinking foam but I have feeling it may melt.........so maybe something else.
I dont want to use another dash kit, i like this one but would like the deck to be more secure and not tiliting backwards.....
any ideas?
Old Nov 14, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
use some brackstraping to secure the back of the headunit to the whole ac/radio "pod"
Old Nov 14, 2005
MegaHurtz's Avatar
how could the holes not line up? I think you dont have the deck in there properly. I seriously doubt a company like alpine would have non-standard mounting holes.
Old Nov 14, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
i know what he's talking about.. cause i had the same problem with my clarion
when i get a moment and it isn't dark outside i'll post some more pics
Old Nov 15, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Drill the stock bracket if it doesn't work. It should line up, just as MH said,. If necessary, you can remove the cage and iso mount it in there. The iso screws should line up if the mounting cage doesn't. And yes, I'd also recommend using back strapping (can be bought at lowes, home depot, etc in the plumbing section). There should be a screw on top of the deck center in the rear.
Old Nov 17, 2005
k-man's Avatar
thanks for the replies, do have an example of what this backstrapping is?? and where would i attatch it to? the deck and where else?
if i was to get the holes to match up the deck would stick out too much for the metra kit, it sticks out the perfect amount for the other kits that dont flush mount the decks.......thats the problem
Old Nov 19, 2005
LowSky's Avatar
the back stapping looks like a piece from an erector set... most head units include a piece with them at least my clarion did...
FYI i cage mounted mine and i didnt use the standar bolt line but the HU is in there good and tight
Old Nov 20, 2005
until someone with a set of pioneer keys walks up and slides your deck out in 3 seconds
cukaracha
May 16, 2015 02:11 PM
intensity
May 12, 2015 10:43 PM
tylerginevan
Apr 27, 2015 12:29 PM
DaveyD
Nov 19, 2001 02:26 PM
Mokushi
Nov 1, 2001 02:40 PM
