Removing Face Plate?
Old Nov 19, 2005
Roosbok's Avatar
Roosbok is an unknown quantity at this point
This is a basic question but I couldn't open the DIY thread for Head Unit replacement.
I am thinking about replacing my HU. What is the best way to remove the face plate without damaging it? It must have to be pried off somehow, but I am afraid of scratching it.
Thanks.
Old Nov 19, 2005
Rennen's Avatar
New Mod on the Block
http://www.7thgencivic.com/forums/sh...d.php?t=211259
.ibtl.
Old Nov 19, 2005
Roosbok's Avatar
Originally Posted by Rennen
Thanks. Actually I have an '01. I remembered that H and A had a instruction sheet on this. With the '01 it appears that you don't have to do all the disassembly of the shift plate, but you do have to remove the lower plate. It looks fairly involved but doable. Those retaining clips make me nervous though. Incidentally, Honda Motor Co. does not recommend stereo installation by DIYers, and recommends trained Honda technicians. The question is whether to go for the free Circuit City installation or do it myself. I have had bad luck in the past with the so called 'professional' installations. Where it comes out crooked or there are gaps, etc. They may have a more experience doing it, but I know my car, and would be more careful.
Old Nov 20, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
of course they recomend honda technicians, they equal more profit for honda. Dont worry about the retaining clips. Once you remove the lower plate and take out the two 8 mils, grab onto the whole center assembly and pull. right before you feel like your going to break it, its going to release. Your cars going to be a bit difficult if the center console has never been removed. You can try to use a panel popper to get the center area free, but the soft padding around the console mars easily, so only do that as a last resort
cukaracha
30
Jul 26, 2015 12:01 PM
chrisjackson321
Jul 12, 2015 03:00 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
ballmich
Jul 9, 2015 11:59 AM
Dean Walker
Jul 7, 2015 02:27 PM
