Where do I ground the amp in the trunk ???
HELP needed asap !
I was installing my amp and sub today, but I cannot find a good place to ground the amp. I drive a 2001 sedan.
Any help ? Picture would be great !
Thanks ahead of time
IF you have stock headunit make sure u got the code first bud
ur amp kit comes with a self taping 1/4" screw, just make sure to undo the battrey's negative and then connect the power wire, the ground and the HU ON wire then just redo the battery and u'll figure the rest out buddy
Originally Posted by AntiLoop
i looked everywhere I cant find a screw to take off or anything to tighten down to the body...
Did you guys just screw it into the body yourself ?
U dont need to find a screw. Just use a self tapping screw and go nutz. U can also use the spot of metal that seperated the trunk and the back of ur seats (when u fold down the seats its that big metal bar that goes across the floor of the trunk) That's what I used.
Sep 27, 2015 11:33 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
