Moved HU and now getting Whinning Noise...Help
Old Nov 7, 2005
RBELANGER's Avatar
RBELANGER is an unknown quantity at this point
I recently moved my Alpine HU to where the power outlet was. When it was in the original place it sounded, fine now I get a whining sound with the RPM.
The HU is powering all four Alpine Speakers and I have a pioneer amp and 10" sub in the trunk. Power and RCA run separately. As I said before the install worked great in the original position. I didn’t rewire anything just unplugged it, moved it down and plugged it back in. Any suggestions would be great.
Thanks in advance
Old Nov 7, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
what did you do with the old Accessory outlet (12V cig lighter) if the wire is just chiling behind the HU, then it may be causing some of your problems
Old Nov 8, 2005
RBELANGER's Avatar
I dont think it is the accessory outlet, I pulled the fuse for it so there is no power to it.
Old Nov 8, 2005
you want power wires as far away as possible from the deck. even the instructions tell you this.
Old Nov 8, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
probably all the system wiring thats behind and further down from the power outlet. Try moving your rcas and see if that helps. Do you get the noise just from the sub, or the full range speakers too?
Old Nov 9, 2005
RBELANGER's Avatar
The whinning is very minamal, only here it when the radio is turned low and not at all when the volume os off, and its not comming from the sub only the full range speakers.
Old Nov 9, 2005
try moving your speaker wires around until the noise stops
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
david34
Sep 23, 2015 11:13 PM
pilebuck13
Sep 21, 2015 10:45 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
