I need HELP!
Old Nov 2, 2005
PaCiFiKbAllA's Avatar
PaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond repute
I need HELP!
Sup guys...herez my problem...i have 2 amps...a 4-ch Inifinity and a Hifonics Titan for my Subs...I got it all wired the other day and when I go to power it all on, the Inifinity amp doesn't get any power to it. The funny thing is that the Power light doesn't come on, but the amp starts to get warm. I've disconnected, reconnected and still have this problem. BTW, I don't have a distribution block. I had the MAIN power wire to my cap, and from my cap I had both the amps wired. Am I missing something here? I looked online and came up with nothing.
So in short, my Infinity amp is not turning on. Any suggestions? I need help man!
Old Nov 2, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
swap out another amp and test it. Or if you have access to a DMM, check the voltage on the power terminals and signal cables. If everythings within range, its an internal problem
Old Nov 4, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
check your remote wire
Old Nov 4, 2005
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
are your grounds solid?
Old Nov 4, 2005
MegaHurtz's Avatar
change the thread title to something more descriptive please, as per forum rules
and make sure the amp is not protecting.
