Guys! i need some input
Old Oct 28, 2005
joescivic02's Avatar
Abercrombie and Fitch
I recently purchased this amp from crutchfield...
[/SIZE] Rockford Fosgate Punch 201S
2-channel car amplifier
50 watts RMS x 2
[LIST][*]50 watts RMS x 2 at 4 ohms[*]100 watts RMS x 2 at 2 ohms[*]200 watts RMS x 1 bridged output at 4 ohms[*]stereo or bridged mono output [*]4-ohm stable in bridged mode[*]Tri-way capable (Tri-Way Crossover required) [*]requires 10-gauge power and ground leads — wiring and hardware not included with amplifier[*]120 Hz high-pass, 80 Hz low-pass crossovers (12 dB/octave)[*]MOSFET power supply and output devices[*]MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability[*]TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise[*]Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality[*]NOMAD — advanced protection circuitry for "intelligent" shutdown protection[*]selectable Punch Bass (0/6/12 dB boost at 45 Hz)[*]speaker- and preamp-level inputs[*]10-1/8"W x 2-7/16"H x 9-7/8"D
Now i bought a jl audio w1v2 12 inch sub in a ported box..... the sub is 150 watts rms..... will this amp be good for it? I am so picky, i know in my mind its ok but im just asking input. thanks
Old Oct 28, 2005
i was planning on getting the jl e1200 but this was only $99 to power a w1.... i want a clean sounding system but also on a budget
lilrob1213
37
Jun 29, 2015 06:45 PM
jordan1794
Jun 8, 2015 08:37 PM
dosmastr
May 5, 2015 12:19 PM
wsking77
Aug 29, 2001 05:34 PM
