These subs/deck/amp any good? (n00b)
Words on a User Title
I'm an n00b when it comes to sound, so...
Now that that is out of the way, let's begin...
I'm looking to buy a simple CD/MP3 Player and some subs for my 04 VP...
I'm (at the moment) comfortable with the speakers that came with the car, so I won't be needing those.
I was looking at some decks and found a SONY one...
Sony CDX-GT200
CD player with MP3 playback
And was thinking about these subs and amp, both Rockford Fosgate... the subs are either Stage 1 or Stage 2, depends.
Rockford Fosgate P110S4
Punch Stage 1 10" 4-ohm subwoofer
Rockford Fosgate P210S4
Punch Stage 2 10" 4-ohm subwoofer
Rockford Fosgate Punch 201S
2-channel car amplifier
50 watts RMS x 2
What do you guys think? Any thoughts, good or bad would be appreciated.
And remember I'm on a budget, I'm not looking to spend too much money simply because I don't have much.
Sony CDX-GT200
- CD player with built-in amplifier (17 watts RMS/52 peak x 4 channels)
- plays CDs, CD-Rs, and CD-RWs (including discs loaded with MP3, WMA, and ATRAC3plus music files)
- 3-band equalizer
- switchable rear/subwoofer preamp output
- front-panel auxiliary input
- detachable face
- CEA-2006 Compliant amplifier
- clock
- 18 FM/12 AM presets
- seek tuning
- remote control
- CD frequency response: 10-20,000 Hz
- CD signal-to-noise ratio: 120 dB
- FM sensitivity: 9 dBf
- warranty: 1 year
- molded polypropylene woofer cone
- frequency response 20-200 Hz
- power range 50-150 watts RMS
- peak power handling 300 watts
- sensitivity 85.5 dB
- 4-ohm impedance
- top-mount depth 4-15/16"
- sealed box volume 0.65 cubic feet
- ported box volume 1.25 cubic feet
- Recommended Q-Logic Box Type: 1, 2, 3
- warranty: 1 year
- 60-ounce magnet
- power range 50-200 watts RMS
- peak power handling 400 watts
- sensitivity 85.8 dB
- 4-ohm impedance
- top-mount depth 5-3/8" (without removable magnet cover. With cover, depth is 5-5/8")
- warranty: 1 year
50 watts RMS x 2
- 50 watts RMS x 2 at 4 ohms
- 100 watts RMS x 2 at 2 ohms
- 200 watts RMS x 1 bridged output at 4 ohms
- stereo or bridged mono output
- 4-ohm stable in bridged mode
- Tri-way capable (Tri-Way Crossover required)
- requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
- 120 Hz high-pass, 80 Hz low-pass crossovers (12 dB/octave)
- MOSFET power supply and output devices
- MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
- TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
- Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
- NOMAD — advanced protection circuitry for "intelligent" shutdown protection
- selectable Punch Bass (0/6/12 dB boost at 45 Hz)
- speaker- and preamp-level inputs
- 10-1/8"W x 2-7/16"H x 9-7/8"D
- 1-year warranty
the deck NO dont ever ever ever buy sony for your car
the sub is ok if you are paying 120 or less retail
and the amp is over 2 years old. they havnt made that model since 2003 so dont get it.
So, which deck would you recommend? One that goes along the lines of this one?
What's the difference between Stage 1 and Stage 2 subwoofers?
What amps do you recommend?
Thanks!
[EDIT] Ok, so the Amp is 2003... does that mean it's any bad? I'm just looking to have some subs on my car... I don't want to have all the latest technology (well, for the deck I do, since newer tech means better sound and such... don't know if for amps there is any difference...)
Oh, also, no DVD. I was thinking of adding a DVD to my car, but I just found out they are illegal to have on the dash on Puerto Rico (for obvious reasons...)
Thanks!
Boobies are the mans tinkertoys
For a deck, I would recommend JVC, Pioneer, Alpine, something that has a good rep. The stage 2 sub has a bigger magnet and can handle more watts. If you want a rockford then get the 2, but you might want to look at some more subs. Amps can really vary. If you want some good quality audio stuff with good prices and excellent service.
www.crutchfield.com
www.crutchfield.com
Originally Posted by grenloch101056
the rockford subs aren't that bad for entry level stuff.
So bigger magnet = more watts = better sound?
Originally Posted by ramcosca
Entry level. Thank you. Someone understands.
a comporable system that sounds good would be a
alpine cde-9843 http://www.crutchfield.com/S-XYveTUD...0&I=500CDE9843
although it is worth the extra money for the cda-9847
as far as the amp and sub go they will sound good together but the amp is old. the sub will hit as hard if not harder than an alpine type S.
the amp is a great amp, just because they don't make them anymore does not mean it is bad. i would suggest an entry level alpine for a deck. the rockford p1's are crap. you could get an alpine type r. i also got a 05' comp vr 12 i will sell you if you are interested
exactly, just because the amp is older doesnt mean that it is crappier. no matter what sub you get just make sure that you get a good box, make sure that it is ported correctly. it makes a huge difference!!
I wasn't saying entry levels were bad. I was saying I AM in the entry level.
I'm not a hardcore speaker know-it-all like most of you guys are.
I just know I have some decent Pioneer speakers that came with my 04 and want to add some bass. Studied a bit and I've come up with a list of things that are necessary to install subwoofers: amps and a deck (if I want to enjoy good sound coming from my subs...)
At the time I'm still researching, want to know what to buy, where to look, and how much it's going to be while I make some money to buy the stuff.
Thanks for the offer chriscivic. If you got any pics, info on the condition and such about those, please e-mail: ramcosca@gmail.com. I read in a different thread about the Comps and they sounded like they were some good ones. I am NOT guaranteeing I'll buy, though, but I AM interested... confusing, I know. So some maybe dibs (lol).
So... help a n00b... what does the amp do?
Why do I need an amp to have subwoofers?
And... what the hell are all those options when I want to see enclosures (boxes)??? What's the difference on all those? I read the info on Crutchfield (the Q-box types listed above) but I was left with the same doubt... or even worse!
Ah, by the way, a friend recommended the Ininity Basslink... these any good?
Electric Boogaloo...
The basslinks are severely over priced for the under performance they offer. As for teh Sony deck, no, no, no, no, no again. Do not buy sony I.C.E product ever.
For your headunit, I'd look into brands such as Pioneer, Alpine, Eclipse, Nakamichi.
For your subs, you may want to take a look as Adire Audio;s Shiva, Elemental Designs subs, Resonant Engineering subs, etc. Rockford's punch line has gone down severly in quality since it's inception. Furthermore, the stage 1 and stage 2 subs are utter garbage.
For your amps, there are a lot out there that will get the job done at an affordable price. I won't even go into detail going over decent brands, I will however say that for the money, JBL offers some great entry level power in their BP series.
What does an amplifier do? It does many things. Bare basics that I'm sure you're wondering is it takes the level of a signal by and increases it by increasing the current or voltage. They can also be used to isolate or control a signal and even decrease the level as in a line output converter.
I might recommend going into the sticky at the top and reading through diskreet's thread in there. Some of the original post is inaccurate, but there is good info through out the thread that's very useful for beginners.From there, I'd browse the tutorials at JL Audio's site, especially their section on boxes and subs located here: http://mobile.jlaudio.com/support_pages.php?page_id=141 . It goes into great detail describing the characteristics of all box types, as well as describing the benefits of each type, explaining subs, etc. Their amp tutorial has good info as well, but it is based around their product line. It's located here: http://mobile.jlaudio.com/products_a...php?page_id=30 From there, you might want to go to www.the12volt.com and look at their tutorials, glossery, etc. Good information there as well. Lots of this is covered in diskreet's diy though, as well as the links. Hope this helped some.
damn i luv audio.
ok so basically the only thing that your head unit is going to put out is low voltage audio signal. even if u have a "HIGH POWER" alpine cd player, its wont put out enough power to give u good bass. so...
amplifier: takes the signal from the head unit, draws from your electrical system, and boosts your audio signal.
subwoofer: based on the power of your audio signal, reproduces the low end sound.
if u have a 1000w amp going to (2) 150w subs. youll only get 300w worth of bass and prolly enventually blow your subs. i know...ive done it.
likewise, (this happends more often) if u have (2) 500w subs and a 150w amp...u think ull get 1000w from your subs, but actually after u crank the volume past about halfway, you'll start underpowering your amp, and eventually u WILL blow the speakers.
ok so what u picked out so far is not going to sound too sepctacular
. i mean, the Sony cd player is kinda crapy, and your subs and your amp are pretty low powered.
first determine your price range:
if your on a budget what u picked out will sound, ehh, fine. but if u actually want to hear your system with the windows down, goin 70 on the freeway, you should be looking at about 500-1000rms for your amp, and that 500-1000rms total for your subs. look at speninding atleast $200-$300 on an amp and about that much for subs. u might also be spending about $200 on a decent head unit.
this help?
this help?
just got to best buy and make them cut you a package deal.. they CAN do that, and as previously stated, go with Alpine Pioneer or Kenwood deck NOT SONY and hook yourself up with the Rockford subs of your choice, best buy has the NEW versions of the amps, which are not bad at all. then just buy the 4 year service plans on everything and youll be set. if you want the new model of subs or amp, blow it and take it in for the new one. P.S. the Alpine 9847 is awesome and employees get it for $133.. so offer them 170.. and then tell them since you are buying tons of stuff to give you a discount. i've worked there forever.. i know.
good luck
good luck
Here is some information from White Rabbit's post in the sticky I linked below that may help clear it up a lot. I'm too lazy to type anything real long on this point, so I'm going to cut and paste:
So I would reword the tip to say "bass boost should not be used at all, tune with the gain instead" or something of that nature.
also might be more polite to use less definitive terms when describing the effect clipping has on a stereo. its easy for a scrub to pick out the statement and say "but I heard that subwoofers in cars play like 10% distortion anyways, why should I care about bass boost?" so I might say something like "clipping may damage a speaker" rather than "clipping will kill a speaker", or of that nature. just using a terminology to help make the tips watertight...
this might be a good point in the tips to suggest that power doesn’t blow speakers, people blow speakers.
If I were writing this tip line, I might combine the thoughts in this general area into something like this:
there are 3 basic ways to kill a speaker: mechanical overload, thermal overload, thermal fatigue. power will not blow a speaker, whether too much or too little. you may feed a subwoofer any amount of power you wish. As a general rule, if you can't hear distortion, you will not blow the speaker.
unfortunately, even this is a misleading and fallacious statement. the band pass box user will be delighted and crank the volume, hearing no distortion and thinking himself set. No relationship is made between the three methods of speaker destruction and power handling, such a discussion would most likely be too long and drawn out for a general bulleted tip list.
I dunno, I guess if I had to compress it down to a bullet, I would say something like: "power doesn’t kill speakers, whether too much or too little. overuse of the gain **** plus overuse of the volume **** kills speakers"
and again, its still not enough, it doesn’t call for how much gain or volume! its a tricky one to bullet, I don’t think I can come up with anything that’ll be good.
http://www.7thgencivic.com/forums/sh...=208476&page=1
Those new to the game may want to read through this thread, which is in the sticky, there is lots of useful information in there, throughout the thread. Anyone should read it, really, as adding to that thread only helps others that may have a question somewhere that's not covered.
Might be a good idea to go through the sticky and read lots of the information in there, there are lots of links to car audio basics, etc:
http://www.7thgencivic.com/forums/sh...d.php?t=210136
you guys make this way too complicated. Get some good entry level stuff. My $200 alpine deck sounds better than the old $900 pioneer deck anyway. Then get an alpine amp for speakers $200. Get a sub and an amp for that. Then some speakers. I bewt you could have a really nice sounding system for under $1k.
I'll tell you now, sony sucks and jvc will suck if you don't know how to use it. alpine and pioneer can be easily programed so it's best to go with that. There are so many good subs out there but if the price sound too good to be true, then you know you might not want that. On amps, I say a newer model planet audio amp simply because of the 5 year warranty on them.
Check it..rough list decks good to bad..
- McInstosh
- Nakamichi
- Eclipse
- Alpine
- RF (units that were made by Denon) / Denon
- Sony ES series
- Blaupunkt
- Pioneer
- Panasonic
- Kenwood
- JVC / Clarion
- Sony Xplode series
- Jensen
- McInstosh
- Nakamichi
- Eclipse
- Alpine
- Sony ES series
- Blaupunkt
- Pioneer
- Panasonic
- Kenwood
- JVC / Clarion
- Jensen
One, we do not know the music he primarily listens to. Two, we don't know exactly what the budget is. 3 we don't know how he prefers to hear his music. Some folks like ghetto boom, thanks much in part to mtv and tv shows on their, among other networks. Some like crisp clean sounding music. Some like their highs bright, their mids soft, and the subs as an accent piece. It's all a matter of personal opinion, but to say to go with one certain thing whether it be a deck, sub, amp, etc is ludicrous.
I'll say this as for recommendations, other than letting the budget determine what you buy. There are a lot of brands out there that will accomplish your desires. Some have good reputations, some have bad reputations. Some are in between. And some are unheard of by the vast majority. Find the one that best suits all of your tastes, wants, needs etc the best out of them and purchase that.
