deck with stock car....
Old Oct 22, 2005
gotricebrother's Avatar
gotricebrother is an unknown quantity at this point
aite peeps i just bought a pioneer avic-n2 and was woundering will it drain my battery or will it effect anything in my car, cause alternator and everything is stock.
Old Oct 22, 2005
MegaHurtz's Avatar
youll be fine
Old Oct 23, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
Just make sure you don't use the deck when your car is turn off. If you read the owners manual, it will say that some where in it. Its also common sense as well. Enjoy your N2.
Old Oct 23, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
Only problem is the N2 only operates its dvd functions when driving less then 3 km/h or parked. So if he ever plans on using the N2 for anything besides music / nav or external screens he may want to consider a Yellow Top battery.
In summary, get a new battery if you feel like watching movies or listening to music while your cars off. Stock alt should be fine.
Old Oct 23, 2005
ajhdragon's Avatar
7thgens official a$$hole
thier is a very simple trick to get passed the whole not being able to watch a dvd while driving. it all has to do with the parking break. but it is illegal to do it or tell you how to do it, and i don't wanna get your thread closed.
Old Oct 23, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
sounddomain.com, elitecaraudio.com and several other forums have the e-brake bypass detailed on them. It involves a rocker/toggle switch to the best of my recollection.
Old Oct 23, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
the N2 uses a gyroscope to measure speed... and without opening the unit there is no easy to make it work with the car in motion
Old Oct 24, 2005
phuviano's Avatar
ajhdragon is still correct though. You can bypass it. Its not easy, but it can be done regardless.
I don't know how to do it personally, but I've seen it done.
Old Oct 24, 2005
Actually, there is. I'm gonna post it here(pending approval of moderators which I'll be pm'ing to ask), but do not come back to me if you mess your unit up, because I, in no way will take respoisibility. This has been guranteed to work by several people, and I know a shop that has done this and it work as well. There are two ways. The one I mentioned above requires too much work to install toggle switches, etc, but the method I'm about to post does work and is easy to do. However should you decide to try this, you void any warranty you may have remaining from Pioneer, as they do not warranty equipment that has been messed with to enable the lockout feature. The following method will unlock everything, except you still get the laywer pop-up on the navigation stuff. I don't know of any way to get rid of that. It does, however require some skill with solder, and you have to be very careful in doing this so as not to mess anything up. The mod only takes about 5 minutes, if that. I'll ask Mega if I can post it then get back to you.
Old Oct 24, 2005
After PM'ing Megahurtz, he has said that I can't post the information or an offsite link in the thread, but shall you wish to be privvy to the information, PM me and I'll provide it.
Old Oct 24, 2005
That I know, but as I said in my post the N2 has the speed sensor. As said above modifiying it can be done but its tampering with what like $2k? If this guys got a nice n2 he may aswell have a decent battery
Old Oct 24, 2005
Zeppelin8778's Avatar
Zeppelin8778 is an unknown quantity at this point
sorry i hope this isnt a thread jack, but im having the same issue, i just bought a huge system pretty much, all JL stuff, 12w7, 1000/1, 300/4, some alpine speakers, alpine deck, tv screen, and such, and i will probably need a new battery, cuz i wanna be able to run it when the cars off for at least a little bit, what model of yellow top battery fits in our car?
Old Oct 25, 2005
Standard sized optima.
If you're careful, you can bypass the gyro without worry.
Misfit2613
Jul 30, 2015 09:49 AM
NoobyKid
Jul 13, 2015 07:53 AM
Jul 12, 2015 11:54 AM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
