gauge wiring???
Old Oct 17, 2005
joescivic02's Avatar
Abercrombie and Fitch
gauge wiring???
Hey guys.... i have always been so picky on what gauge wiring I should get for my jl e1200 amp. Its a really small amp........ but says it accepts up to 4 gauge wire? Now Ive been working with audio for a while now but why would the intstruc. to this amp say it would require up to 4 gauge? Will my 8 gauge be just fine? The amp is only pumping out 150 rms... so no need at al for 4 gauge..
but can anyone tell me why it would accept up to 4? Ive always wondered this about the amp.. thanks. Im so picky when it comes to this. Not a lot of current is coming and going through so.......
Old Oct 17, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
U could go down to 10ga if u wanted to cuz its only 150 rms.
They make them bigger for idiots who like to waste their $ on excess wire that isnt necessary. But technically, the current flows easier with a larger wire cuz its less likely to be restrictive during a peak power burst. bigger = better. its the American way
Old Oct 17, 2005
8 gauge is more than okay
Old Oct 17, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
marketing, plain and simple. If you owned a store, wouldnt you rather sell a 4 guage kit compared to an 8 guage kit
Old Oct 17, 2005
performance sys's Avatar
performance sys is an unknown quantity at this point
Exactly!
For 150rms, you are more than safe using 8 gauge wire.
Old Oct 17, 2005
MegaHurtz's Avatar
you contradict yourself... are we idiots becuase we use the best (biggest) power wire possible or are we smart for creating the best possible current flow?
Old Oct 17, 2005
^^^ yeah but he is trying to say its ok for me brotha. 8 gauge for 150 rms is more than enough. thanks guys
Old Oct 18, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
use a thicker wire only if you plan on adding more amps or what ever to the system... this way you wont waste even more money and time wiring your car again..
my amp recommended using 8 guage but i went with 4 so when i add another amp I'm set only cost me $20 bucks more
Old Oct 19, 2005
ruckerheadz's Avatar
ruckerheadz is an unknown quantity at this point
4ga power wire??? 8ga power wire????? i thought that was speaker wire, jk for me it is, but like the other guys said if u got 4ga use it but if u dont wanna spend money ur 8ga will be fine.
Old Oct 19, 2005
Kyle23's Avatar
I c what ur saying.... I guess what I meant is that the people who have really weak amps and get like 0 ga wire which is overkill when 4 ga would normally b way more than what they needed....
Like if our buddy used 0 og for his 150w RMS amp when 10,8, or 4 would be more than enough but they just get 0 u be special....
Or u can look at it as getting the best available. I can see it both ways
BootyDo
Jun 21, 2016 03:45 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
JUNITO
Jul 9, 2015 08:36 PM
robbie374
Jul 7, 2015 02:56 AM
werdnahall
May 17, 2015 11:37 AM
