Running wires from amp to speaker?
Old Oct 3, 2005
dacali's Avatar
dacali is an unknown quantity at this point
I'm going to be running new speaker wire (Knu Knoceptz 12 Gauge) from my amp (in trunk) to my front speakers.
I'll probably be running my power cable down the passenger side and the RCA cables down the driver side. Where should I be running my speaker wire? Thanks in advance for the help!
-Dacali
Any harm in mounting the amp on the back of the car seat? I noticed it was slanted more than I would have liked. I'm slightly worried about the amp overheating.
Old Oct 3, 2005
joescivic02's Avatar
Abercrombie and Fitch
you can run the speaker wire wherever............ as for the amp look in my pics... i bought quarter inch plywood and slid it in the backseat and screwed my amp on that.....
Old Oct 3, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
i would run the speaker wire on the driver side and try to keep it as far away from the power wire as you can. mainly because its easier to just run both wires up at the same time. also if there is engine noise atleast you know its from the power wire.
Old Oct 3, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
Also, I'd run the signal cables down the passenger side rather than the drivers. You wont have to pass all the system wiring and fuseboxes which put out some nasty noises
mistermenphis22
Apr 3, 2016 08:06 AM
jackoncruzpr
May 24, 2015 12:24 AM
Crashoveride
Dec 29, 2001 09:40 PM
2k2civic
Dec 2, 2001 11:35 PM
mohawkboom
Nov 2, 2001 06:00 PM
