where to install?... check it out
Old Sep 25, 2005
steven10's Avatar
steven10 is an unknown quantity at this point
i have the basslink remote... and i wanna install it in one of those squares right there
Old Sep 25, 2005
SLO REX's Avatar
250+ awhp Stage 2
Old Sep 25, 2005
SLO REX's Avatar
250+ awhp Stage 2
learn to link pictures.
Old Sep 25, 2005
steven10's Avatar
sorry about that.. i messed up... please take a look again and help me out...
Old Sep 25, 2005
SLO REX's Avatar
250+ awhp Stage 2
Just install it under the dash on that piece that comes out. That is where mine is.
Old Sep 25, 2005
steven10's Avatar
u got pics?... that little square piece?.. can i pop it off and put the basslink remote in there?
Old Sep 25, 2005
SLO REX's Avatar
250+ awhp Stage 2
Old Sep 25, 2005
steven10's Avatar
u just stuck it on there? is there any way i can get it inside that square i circled in red in that picture up there? or no?
Old Sep 25, 2005
SLO REX's Avatar
250+ awhp Stage 2
Yeah that piece comes off. I will go get more pictures for you tomorrow if you need them.
Old Sep 25, 2005
SLO REX's Avatar
250+ awhp Stage 2
Well anything is possible, but having it hidden, IMO, is best.
Old Sep 25, 2005
MegaHurtz's Avatar
you CAN take that piece apart and jsut take the **** out, right?
btw, here's my install, PG LPL44
Old Sep 25, 2005
steven10's Avatar
isnt that square im talkin about for like the fog light switch? has anyone installed anything there before?.. do u have like a DIY or pics on how to pop it off... and install in there?
Old Sep 25, 2005
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
That's exactly where i have my remote base control. It takes about 10 mins to take out the center console. Once you got it out, unplug the cigarette lighter. Pop out the plastic piece.
Now there's really no way to hold the controller in place. So what I did was superglued the face of the controller to the back of the piece. I have it there for a year now and the superglue seems to be holding it pretty tight. It might get sloppy so have something to wipe the glue before it dries, and super glue does dry pretty fast.
Old Sep 25, 2005
MegaHurtz's Avatar
there should be 2 squares in the center console, one would be for oem fogs if you have them, otherwise it will be blank. the one that I installed my bass **** in would be for the sunroof controls, but I obviously don't have a sunroof, so there it is.
Old Sep 25, 2005
steven10's Avatar
oh ic i c... i need some help on how to pop that little square off and that center part to install it correctly...
Basically how do i take that little sqaure out in order to install my basslink remote... also how can i run the wire to the remote once i get it in there... please help! =] tryin to do this ASAP... but i need to know how haha
Old Sep 25, 2005
MegaHurtz's Avatar
If you want to do it where the coin tray thing is, there's one screw at the top that you can get at when you open it up.
If you want to do it in the center console piece, search.
Old Sep 25, 2005
steven10's Avatar
i wanna do it where the power outlet thing is.. but i been searching and i cannot find anything on it... i really wanna do it soon... my main question is do i have to take out like the whole thing including the part where the shift **** is in order to get to those squares or does that bottom part com out by itself?
Old Sep 25, 2005
steven10's Avatar
bump
Old Sep 25, 2005
drew22mader's Avatar
There is gl@ss in my @SS...
Hey, this is where my bass **** is located, I have the sunroof button so that wasn't a choice, i like it where it is, easy to get to.
Old Sep 25, 2005
steven10's Avatar
that looks so clean... thats exactly where i want to put mine!.. please help me out on how to do that... just like that!
Old Sep 26, 2005
jay78's Avatar
jay78 is on a distinguished road
dont install that dude.......it distory sound...mine sound better without...bass link...
Old Sep 26, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
[QUOTE=steven10]i have the basslink remote... and i wanna install it in one of those squares right there
That's where I put both of mine.... U would have to take off the top mounting bracket most likely so that it will fit. I have 2 amps so both of those slots r filled
Old Sep 26, 2005
7thGENDMAN's Avatar
7thGENDMAN is on a distinguished road
dude, just pull on the bottom part there and it should come right out. You will have to take out the squares and open them up abit from the back, but it shouldn't be a problem. Just grab that little bottom half and pull.
Old Sep 26, 2005
Jay78, it won't distort anything, doesn't do a single thing to mine. On my Cd player i don't have the crossovers hooked up at all. Its all going through the Kicker KQ30 30 band EQ.
Old Sep 26, 2005
7thGENDMAN's Avatar
yeah, sounds like you had your gain way too high and them when you added the bass boost it got distorted. Mine was like that for a while until I had time to tune it. Just turn the gain down alittle and use the bass boost to control bass levels.
Old Sep 26, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Try the DIY headunit install it shows you how to take it out. 01-03, you can pull it off. 04 plus (maybe 03) you have to take more apart.
I still like where White Rabbit installed that one he did best. Undet the E-brake in that pocket. He drilled the hole and it came out under the e-brake, on the vertical side. Looked real clean and you wouldn't see it unless you looked.
Old Sep 26, 2005
flyguy050's Avatar
flyguy050 is an unknown quantity at this point
Yeah thats where i had my bass **** before i put the cd player in there...easy install....drill hole and super glue....pretty easy
Old Sep 26, 2005
I've told him already, where the DIY was, and everything, how to do it too. I've told him a couple times.
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
