Help with REVERSE indiglo gauges
Old Sep 25, 2005
soltex's Avatar
soltex has a little shameless behaviour in the past
Unhappy Help with REVERSE indiglo gauges
Well i just got some gauges, install them and works great with no hassle. But the problem is that the tape from the bottem keeps coming off when its gets warm from the sun. Just using regual double sided tape. Then the needles dont work cause the new gauges hit then and they dont stay on the bottem
I have opened it like 5 times and tired of it. Everyday, gets hot the tape gets loose.
ANy special idea's.???????? Help me
Old Sep 25, 2005
streetglower's Avatar
try using glue. Mine are glued on and I have never had problems. Once they stay down, the needles should work unless they are sticking in which you need to pull them back a bit.
Old Sep 25, 2005
or put small pieces of tape on the sides where it won't be visible once everything is put together.
Old Sep 25, 2005
D5cIvIc's Avatar
i had the same problem when i was using some thick no brand name double sided tape. I then went to staples and got SCOTCH double sided tape. Make sure its just the regular thin kind. I placed about a few pieces of the scotch double sided tape on each indiglo thing and it never moved ever again. I don't recommend glue becuase what if you wanted to take them off later. Try that and let me know how it goes. it should work.
Old Sep 25, 2005
D5cIvIc's Avatar
also make sure you get the regular THIN double sided tape. I had the problems of the needles hitting when i used the scotch 3M tape that was all thick. I know i was stupid.
Old Sep 25, 2005
hdave's Avatar
hdave is an unknown quantity at this point
take a few pics of it.
i want to make my guages blue to match my deck, but dont want to spend too much time or money on it.
Old Sep 25, 2005
soltex's Avatar
http://www.7thgencivic.com/memberrid...icture_002.jpg
Here ya go. Yeah just took them of for now. Until i get some tape
Old Sep 25, 2005
soltex's Avatar
Yeah wont use glue. Would make a mess
Here are my gauges from ebay
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Old Sep 26, 2005
flyguy050's Avatar
flyguy050 is an unknown quantity at this point
Ebay is the best place for sure, got mine fo 25 bucks and they look good... I used double stick tape and had the same exact problem. used super glue and havent had a problem since. Make sure you dont get generic super glue though cuz some turn whiteish when it dries, not good cuz its kinda hard to get off...
Old Sep 26, 2005
soltex's Avatar
Glue, dont you think its gona make a mess????
Old Sep 26, 2005
D5cIvIc's Avatar
why would anyone even think of putting glue on the back of their new gauges and stick it on your stock gauges?? i really don't get this. JUST USE SCOTCH DOUBLE SIDED TAPE. the REGULAR THIN KIND. there is no way your needles will hit it if you used the regular thin SCOTCH double sided tape. NO WAY AT ALL. its probably less than a 1mm thick. be sure its SCOTCH though, those double sided tapes are the best imo.
Old Sep 26, 2005
D5cIvIc's Avatar
i hope you guys that used the krazy super glue on the gauges never have their gauges go out or i really do think its going to make it very hard to take off, and not to mention the glue that is going to be left on your stock gauges.
Old Sep 26, 2005
soltex's Avatar
The tape works man doulble sided. But it gets lose you know the hot weather, and than it lifts from the bottem.
Old Sep 26, 2005
D5cIvIc's Avatar
really? i had mine on for over a year now and never ever had a problem, but eh
Old Sep 26, 2005
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
Had the same problem with mine... Got tired of having to constantly take apart my gauges so I just took them off and did a cluster swap from an 04 sedan.
Old Sep 27, 2005
Mine are glued and look fine. Yea I cant remove them but I got indiglos because I love them and didnt ever plan on removing them. Now using the right kind of glue and doing it right would yeild no problems.
Old Sep 28, 2005
soltex's Avatar
**** it just took them off, will install them later on, when i find some good tape
Old Sep 28, 2005
D5cIvIc's Avatar
What kind of glue did you use? all i'm concerned about is when your indiglo gauges go out, how are you going to take them off without damaging your stock gauges?
Old Sep 28, 2005
D5cIvIc's Avatar
Scotch man, SCOTCH TAPE
Old Sep 28, 2005
jay78's Avatar
jay78 is on a distinguished road
i hve gauges on my car for almost 2yers...i didnt put no tape or glue in the back....naver had problem so far.....all i did is put it on top of stock gauges and line them up...their is like two needle at the bottom of rpm and mph gauge make sure they are in... after u do that make sure your gauges are not touching the needles at the bottom ......put the cover on carfully put it back together... and go on the highway go up 80 90 see if needle stuck....
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ThatGuy913
Sep 28, 2015 05:35 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
