Neons not working properly. *HELP*
Old Sep 20, 2005
djkidkaz's Avatar
djkidkaz is an unknown quantity at this point
I just noticed the other day that my underground neons wont stay on. I start the car, turn them on and then a little bit after that, they turn off. And if I turn the switch off and then back on they will flash on for a second and then go off. But if I turn the car off and turn the key without starting the car, I can turn them on and they stay on. Any idea what the problem could be and any possibly solutions I could try to fix this? Thanks!!
Old Sep 20, 2005
AlienX's Avatar
AlienX will become famous soon enough
#1 solution: Take them out of your car, locate the nearest trash can and dispose of.
j/k dude
check your grounds.
Old Sep 20, 2005
EnProceso's Avatar
loose connection maybe?
Old Sep 20, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
What underbody neons do you own?
Old Sep 20, 2005
RobbyB's Avatar
RobbyB is an unknown quantity at this point
ya sounds like a loose connection, imo under neons are hurt, id rather grab a flashlight attach it to the bottom of my car and let it shine on the road so people will be like damn thats crazy.
Old Sep 20, 2005
jay78's Avatar
jay78 is on a distinguished road
as he said check your ground or find better ground....
j/k dude
check your grounds.
Old Sep 20, 2005
ragencajun's Avatar
ragencajun is an unknown quantity at this point
ground or loose conection 95% sure if thats not it get stoned and think about it for awhile
Old Sep 20, 2005
Mmm, either ground, or a damaged tube.. THOROUGHLY check every tube.. all it takes is a tiny crack somewhere
Old Sep 20, 2005
MegaHurtz's Avatar
something loose probably, or could be a heat issue
ORskier
May 3, 2015 12:54 PM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
viper775
Nov 15, 2001 10:54 PM
Inspired2k1
Nov 14, 2001 05:18 PM
