Need help re-installing my factory head unit
Old Sep 19, 2005
e22s's Avatar
e22s is an unknown quantity at this point
i was trying to hook it back up cause im trading it in and needed to take my system out and put it back to stock but when i hook the factory unit up it doesnt turn on when i turn the car on and when i push the power button on it, the screen just says "CODE" ....i have a 2dr 04 civic...what do you think i did wrong or what happened...thanks for the help
Old Sep 19, 2005
xxhonda4lifexx's Avatar
xxhonda4lifexx has a little shameless behaviour in the past
You must have an EX with anti-theft code protection. At the time of purchase, the dealer should have given you the unlock code; check your owner's manual. If you have lost the code, you can obtain it from the dealer.
Old Sep 19, 2005
e22s's Avatar
ok thanks. now i have another problem with the door speakers. for some reason my dad cut the harness to the door speakers. on the passenger side door theres a dark green wire with a black stripe and lime green wire (i already hooked thhose wires together) but on the other door there are 4 wires, 2 grey with red stripeds and 2 green with yellow stripes, wich 2 do i hook up to the door speaker? thanks for the help agin
Old Sep 19, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
use a meter to see which one is negative and which is positive. try using the search button and search for "wiring diagram" u should find what ur lookin for
Old Sep 19, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
If they're the same colors, match teh colors up.
4 banger
Jun 5, 2015 01:44 AM
rawtalent14
Jan 22, 2002 09:29 AM
bobbyd
Jan 7, 2002 01:31 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
