Whine in Rear component speakers when rca cable unpluged
Old Sep 9, 2005
sleeper2002's Avatar
sleeper2002 is an unknown quantity at this point
I am about to give up on my rear component amplifier. I have tried all of the steps in eliminating alternator noise (grounds for amps and HU, upgraded rca cables, audio / power cable positioning, amplifier gain) but nothing has helped.
I am not sure if my case is different but I am also getting noise in my rear components even when the rca cables are not hooked up. The power, ground, remote, and speaker wires are all hooked up with the exception of the rca cable. Does anyone have any ideas? I am about to get some coax speakers for rear fill and just hook them up to the HU amp.
Thanks in advance
Old Sep 9, 2005
MegaHurtz's Avatar
why would you replace teh speakers if they are getting whine when they arent even hooked up?
Old Sep 9, 2005
My CDT's need more power then my Alpine 9827 can give them
Old Sep 9, 2005
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
what brand of amp?
Old Sep 9, 2005
Pitch_BlacK's Avatar
Pitch_BlacK is an unknown quantity at this point
What are the rca's for? how come their not hooked up. Do you get a whining noise when its hooked up or not hooked up. If u get noise when its unhooked make sure that you don't leave the rca cable bare. Put some rubber or vinly tape to cover it. Maybe that is the cause.
Old Sep 9, 2005
Did you just run your audio wires bare? or you use a wire loom. I used wire looms for all my wires that's why I have clean signal.
Old Sep 12, 2005
The amp is a newer model US Acoustics 2080. I just searched the car audio forums and found out that these amps have unshielded inputs sensitive to grounds. Oh well, I would rather get a new amp then replace my CDTs.
Old Sep 12, 2005
Bigfella's Avatar
Bigfella is an unknown quantity at this point
I think this sounds like a bad earth, (or grounding as you may call it), make sure the earthing is good and if possible earth everything at the same place, this stop earth looping (i think its called that anyway).
Old Sep 12, 2005
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
leave the rears out? just use fronts...
Old Sep 12, 2005
2slow2run's Avatar
wut time is it now
2slow2run is an unknown quantity at this point
r u talkin bout the noises when u step on the gas pedal?
cuz i have it now since i install another amp for the subs
im guess'n is my power wire or something.
well ne1 ever fix it pls post
ty
Old Sep 12, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
To me, it doesn't sound like he's having ground loops.
What type of noise are you getting?
Old Sep 12, 2005
2slow2run's Avatar
wut time is it now
sure is not the deck? cuz my speakers have that static noise when the song end n start if volume is not up
Old Sep 13, 2005
Bigfella's Avatar
Remember that the RCA is not connected and there is still noise that indicates either bad grounding maybe, but cant be attributed to the HU, cos it aint connected.
Old Sep 13, 2005
2slow2run's Avatar
wut time is it now
does ne1 noes bout the noise when u plug in everything n everything works n stuff
but like when u step on the gas theres like a whine noise sound like ur car got boosted in a bad way
how do u fix that?
it is cuz of the powr? (do i need a cap? cuz i dont have ne install)
this is the setup i have
1:1 kenwood amp for all the speakers
2:1 kenwood amp for the 2 12" subs
b4 #2 everything was fine now its just
ill probably disconnect the #2 over the weekend n then install a diff deck n c how it will sound but if ne1 fix that problem
Old Sep 13, 2005
coop's Avatar
cheaper amps generally do not have very good noise filtration.
Old Sep 13, 2005
Bigfella's Avatar
how do u fix that?
You can buy a thing called an alternator suppressor that would help, but that only cures the symptoms and not the cause. Likely causes are poor rubbish unshielded RCA's or again a bad earth or grounding.
Old Sep 13, 2005
2slow2run's Avatar
wut time is it now
well i found the reason.
something bout alpine deck is hella good
i switch the sony the 1 wit the flip face n non detatchable wit the alpine cda9827
n problem solve
Old Sep 14, 2005
coop's Avatar
Interesting - I would have suspected the amp as your source of noise, not your deck but regardless, Alpine makes quality product.
Old Sep 16, 2005
The noise was coming from the amp. Don't buy the newer US acoustic amps they suck.
fatih717171
Jul 25, 2016 06:22 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
mistermenphis22
Jul 13, 2015 04:43 PM
SpecialRequest
Jul 7, 2015 07:52 PM
Causemo
Jul 4, 2015 07:11 AM
