A Quick AMP Question
Old Sep 8, 2005
soltex's Avatar
soltex has a little shameless behaviour in the past
Cool A Quick AMP Question
Wanted to know if i get this amp. WOuld i have any car problems like lights dimming or anything like that.
The amp Fuse rating is 80. Would i be ok.
Got an 02 civic LX
This AMp
http://cgi.ebay.com/ws/eBayISAPI.dll...%3AUS%3A1&rd=1
pss. ALready orderd a Pioneer 670MP Premier to go with it
Old Sep 8, 2005
ncirom2003's Avatar
yes, get a 1 farad capacitor and there will be no dimming to worry about.
Old Sep 8, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
yea it will work but your going to have to keep it down if it actually runs at those numbers...rec. caps and deepcyl batts
1 x 900 Watts @ 1 Ohms
1 x 1200 Watts @ 2 Ohms
less power with less resistance- something wrong with those numbers
Old Sep 8, 2005
soltex's Avatar
hmmm
Old Sep 8, 2005
soltex's Avatar
I heard that Capicitors a Worthless and they dont help alot.
Old Sep 8, 2005
ncirom2003's Avatar
you heard wrong, they will help.
Old Sep 8, 2005
diskreet's Avatar
you will have alot of dimming with that amp. with almost any amp you get dimming.
I have a 1 farad cap and almost no dimming, but there is still some there.
caps arent worthless. people are retarted and for some reason everyone tries to scientifically prove they do nothing. the really do do something. they store energy.
if they were useless would you see them on motherboards, ECU's, and just about EVERY electronic device you have ever used?!
They have a purpose. And in a car audio set up they help the car maintain a higher voltage, which means less dimming.
all you need to know is you will have LESS dimming with a cap. not NO dimming, but LESS.
Old Sep 8, 2005
soltex's Avatar
Red face
So that amp will cause dimming. What kind of amp you using. Any good ones you recomend with higher wattage. good price range?
Old Sep 8, 2005
ncirom2003's Avatar
its not the amp, its the current pulled that causes dimming, id say anything over 500watts will cause noticeable dimming.
Old Sep 8, 2005
i have a total of 1000 watts rms on my car, 2 4 gauge kits and 2 1 farad and 1 1.5 farad cap[s] in my car and i cant even turn my bass amp up past a 1/4 because voltage runs bellow 11 volts and amp runs in diagnostic, i am getting a group 27 batt this weekend, and if that doesnt fix it, a 80farad digi cap, i payed for that power i want to use it!
Old Sep 8, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
that amp will definatly dim ur cars lights. WTF is up with the ohm rating on that thing?
Old Sep 8, 2005
ncirom2003's Avatar
and sorry but its hard for me to believe that a hifonics is rated to a 1-ohm load.
Old Sep 8, 2005
diskreet's Avatar
Im running a JL 500/1, which is 500 - 600 watts RMS (different ratings from different sources) at 4 ohms.
my cap is a lightning audio cap. 1 farad. i recommend them to anyone, they are cheap, and have a very quick discharge; faster than most other caps.
Old Sep 8, 2005
soltex's Avatar
How many RMS are your Subs. Can the Jl push them easily. I might get that with the Lightning Audio cap.
Old Sep 8, 2005
ncirom2003's Avatar
youve got to do some research, not tryin to be a d!ck but i used to have no clue about this stuff and i read some stuff and asked some people. learn some things and you can make a better system cheaper too.
Old Sep 9, 2005
soltex's Avatar
Yeah thats what i am trying to do. I already got the deck,kit,dashkit . for 179
Looking for an amp in the 150 range Going to the flee martket tomorrow.
Civic65
Jul 19, 2015 10:13 AM
NoobyKid
Jul 13, 2015 07:53 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
