neon light switch
Old Sep 2, 2005
01civicdriver's Avatar
01civicdriver is an unknown quantity at this point
neon light switch
i have neon lights for the inside of my car. i was wondering how to hook them up into the fuse box so i dont have to take out my 12v outlet. i just need to know how to hook it up with the fuse box. thx
Old Sep 2, 2005
honda860's Avatar
honda860 has a little shameless behaviour in the past
I wrapped my wires actually around a fuse in the fuse box and then ran wires for a switch to the little tray behind my shifter and installed a switch
Old Sep 2, 2005
so how do you get the power? im not that electrically smart. i get easily confused with it all. thx
Old Sep 2, 2005
honda860's Avatar
****, if i have some time i will write u up a DIY. I dont have neons on my car anymore it me it seems ricerish but i had em on my old vic so If i get some time i will write u up one
Old Sep 2, 2005
usafcushman's Avatar
7thGen's Loudest Civic...4,000 watts and climbing...
usafcushman is on a distinguished road
go to Auto Zone or whatever you have in your area and pick up a rocker switch, a fuse tap, and a relay (you can get all 3 for like $10)... the relay will have instructions on the packaging showing how to hook it up (if it doesn't, just do a search here or at sounddomain.com)... one of the prongs on the relay will be where you need to hook up a power supply, and that's where the fuse tap comes in (instructions should come with this item as well)... and finally, just wire up the switch (input, output, and ground) along the power lead...
that probably sounds confusing as hell, but i only have another minute or so before i gotta haul a$$ back to work... if you still need help in a couple hours, i'll stop back by and see what i can do for you... check out my web site (link in my signature!), there's a couple pics of my switch, relay, and fuse tap install on page 2... good luck!
Old Sep 2, 2005
EnProceso's Avatar
another simple way...
get some 16gauge wire, inline fuse, and switch (rocker, toggle, etc...) run 12" of wire from the + side of the car battery, hook up the inline fuse, run the rest of the wire through the firewall to your switch.
or even just tap into the cig. lighter wire behind the dash. that was my method.
Old Sep 2, 2005
good info... however, that's exactly what a fuse tap is: 16 ga wire with an inline fuse, it just goes in your fuse box instead of connected to the battery itself...
Old Sep 2, 2005
jay78's Avatar
jay78 is on a distinguished road
as he said....easy way to tap into the cig lighter.....put the toggle switch between ground wire....should take you 10mints and u done...
thants how my tv screens are hookd....
AlpineCivic
111
Oct 20, 2003 07:31 PM
LuvMyCivic
Dec 12, 2001 10:02 PM
klam
Nov 16, 2001 03:36 PM
viper775
Nov 15, 2001 10:54 PM
NukeSilo
Nov 4, 2001 09:37 PM
