System help..can anyone tell me whats going on ?
Old Aug 26, 2005
RAA6785's Avatar
RAA6785 is an unknown quantity at this point
ok heres the deal...i didnt changed out my old Headunit..so i bought the coverter so i could keep my stock deck.....i tapped the rear speaker wires to connect to the converter and then connected up the system like normal....now heres the thing...there is power to the amp and it turns on and off wit hthe car like i had wired it to do....the problem is that no sound is coming out of the subs...no bass at all ...i checked and rechecked the connects and even made sure the polarity was right.....i have no ****in clue whats going on ..i have the Tsunami converter .. idunno if anyone else has used it ....they said (the instructions that is ) that you could make a common ground ..and there is also a brown wire which they said that "If the thing is properly installed and you get no sound to connect it to the ground on the amp...." did thayt and still ntohing ?......if anyone knows what could possibly be the problem and could help me out that would be awesome ..thanks for ur help
Old Aug 26, 2005
MegaHurtz's Avatar
do the amp and the LOC turn on?
Old Aug 26, 2005
RAA6785's Avatar
they isnt an 'on' switch for the LOC ...it's just connected to the positive and negative speaker wires that go to each speaker....i'm thinking the amp could of blown cuz it wasnt the best made one ..so i dunno...thats the only thing i can think of ..i checked the grounds cuz a buddy of mine had the same problem.....but i dunno..what i need to do is find another working amp and test it out ...if it works then i know it;s the ****in amp...
Old Aug 26, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
of get a cd player or mp3 player and hook it up to the amp's inputs and set the volume to low intiially. if you get no sound outa the amp, you know thats the problem. if you get sounds, the LOC is the issue
Old Aug 27, 2005
RAA6785's Avatar
wait say that again im not sure i understand what you mean
Old Aug 27, 2005
jay78's Avatar
jay78 is on a distinguished road
here this is wat i use to have in my car with stock...redio....
all i had to connect speaker harness wire to converter input wire......ground u dont have to connect but u might get some ground noise..if u dont....but still works....
then u connect the rca out put to your amp...2ch or u can add splitter for 4ch amp...
reconnect all your wires....
let me know if this help.....
Old Aug 27, 2005
RAA6785's Avatar
i redid the wire..checked again...i talked to some of my friends that are skilled with systems..they think it's the amp too...(the amp was only ****in like 60 bucks BRAND NEW ..it's Pyramid ..some B.S company.,..prolly not even good quality..).....the amp powers on but gives no sound ....im thinking that it's gotta be the amp...thats the only thing left.....i've double/triple/checke all wire connections...i used wire taps ..and all the tap are making proper contact.....what do u think ?....I even intentionall broke the LOC to return it and get a new one cuz i thought that could of been the problem..but still to no avail...no sound..ughhh this is so frustratingggg....i just wanna hear some basssss ..lol...thanks for ur help
Old Aug 27, 2005
to test if the amp is the culprit, go to radio shack and get a cable that has a male headphone jack on one side and two male rcas on the other. Connect this to the input of the amp with the volume on whatever your using to test it turned low. If you get music out of the amplifier, you know the LOC is the problem.
If no sound comes out, the amp isnt doing its job.
Old Aug 27, 2005
RAA6785's Avatar
I really think it's the amp...but before i go out and buy another amp i wanna check it someone elses to see ..cuz if i get sound then i know it's the frickin amp....but yea i just dont wanna spend that money for a new amp and then have it NOT be the amp
Old Aug 27, 2005
jay78's Avatar
if your buddy got system....askhim if he can let u plug the rca wires to his amp...make sure his car is running...sound from your redio...connects to his amp....if he dont wont to unplug his amp...this is easyest way,..to chek....make sure u hve long enought rca wires to his amp....
anyway u should get better amp...dude
Old Aug 27, 2005
jay78's Avatar
i will do wat he said.....should be like $4.00......try it in their parking lot.....test it then return it lol...
Old Aug 27, 2005
RAA6785's Avatar
mmm...yea im actually gonna wait to try my buddy's amp in my car and see if it powers the subs ..if it does..i guess thats another 200 i can kiss goodbye..lol
Old Aug 27, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
did you check connections inside the sub box? Also did you check the settings on the amp like gain and other options? Also double check the amp to see if it has speaker level inputs as well as RCA. There might be a switch that needs to be flipped to move it to the RCA inputs. If you have access to a multimeter you can check signal strength at all your connections, but i'm guessing you don't.
coumadin01
Electronics
25
Jul 25, 2019 04:19 PM
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
